4th genners with JDM headlights help
Old 05-15-2003, 05:08 PM
EFing8's Avatar
Default 4th genners with JDM headlights help
I got my JDM headlights for my 90 accord. How hard is it to make them fit and how do you wire the headlights, how do you also change the bulbs if they are burnt out. They are totally different than the USDM ones.
Old 05-15-2003, 07:38 PM
93accordEX's Avatar
Default Re: 4th genners with JDM headlights help (EFing8)
really essentially the same. first to mount you just need to cut a slight bit of the inner bottom post that comes down to hold it on cause it will hit the bumper mount.
see how the inner bracket is like an L while the one next to it is a diagonal. anyway yea so cut that. changing bulbs is basically exactly the same. wiring is really easy. cheapest/easiest, cut off the old harnesses and just splice into the new ones. the bulbs in the corners are the only difference to change but honda convienently put some extending cover over the bulb so you can pull it out through the engine bay.
TegLSTypeR
08-17-2010 08:18 PM
moegets
06-27-2010 08:07 PM
hialeahzbg
02-21-2006 07:50 PM
Easyslider01
09-07-2005 07:46 AM
Troy
09-16-2002 04:54 PM
Quick Reply: 4th genners with JDM headlights help
