2002 Accord: Belt squealing when starting after replacement
Old 07-05-2014, 06:40 PM
Jason777's Avatar
Icon2 2002 Accord: Belt squealing when starting after replacement
I had a mechanic replace some belts on a 2002 Accord EX 4-cylinder. The mechanic told me the following belts are replaced:
  • Timing belt
  • Balancer shaft belt
  • Serpentine Belt
  • Power steering belt
  • Water pump
After a few days I noticed when starting, sometimes I could hear squealing for a few seconds. After that initial squealing everything would be OK.
I took it to the mechanic and he did some belt adjustments. The squealing problem seemed to be fixed.
But now after a month, the problem came back. However, the squealing duration has significantly decreased, to less than half a second compared to around 3 seconds before the adjustments.
It doesn't always squeal when starting. It is more likely to happen when starting in cold weather.
I'm not very good with cars so I'd be very grateful if you guys could give me some advice. What's the cause of the squealing? Did my mechanic use the right belts? Did he install the belts correctly? Is it necessary to do more adjustments?
Thanks!
Old 07-05-2014, 07:35 PM
tim73's Avatar
Default Re: 2002 Accord: Belt squealing when starting after replacement
Is the AC on when it squeels? Maybe the Ac or the alternator betl, probably not a big deal, he might have used a cheap belt.
Old 07-05-2014, 08:13 PM
Jason777's Avatar
No the AC is not on.
Old 07-05-2014, 08:33 PM
MM Gruppe B
MAD_MIKE's Avatar
New belts may stretch a bit after install, recheck tension or have the mechanic readjust it.
Old 07-05-2014, 11:36 PM
holmesnmanny's Avatar
+1
Perhaps if the belt was originally tensioned to spec it may not squeal even after a few days of engine running since new belts stretch a bit a few miles after installation, if the new belt was originally a little loose than it should have been, it's going to squeal after a few miles, no doubt.
On the longest side of any serpentine belt, in the very middle of that side, if you can twist it more than 90 degrees the belt is too loose. So check it.
Old 07-06-2014, 12:51 PM
onunezp's Avatar
Originally Posted by holmesnmanny
+1
how can i tighten the alternator belt? its making a horrible squeal when i turn the car on, thank you.
Old 07-06-2014, 01:55 PM
onunezp's Avatar
ok, i did it myself by following instructions in this video,
clockwise to tighten
Jason, do it to see if corrects your issue, worked for me!
Old 07-07-2014, 02:06 PM
Jason777's Avatar
Thanks guys for the advice and video. I'll try and let you know.
techsupport
03-29-2017 08:43 PM
aznromeo4u
02-18-2015 07:51 PM
famfive
07-25-2010 08:29 AM
1baddcivicsi
05-03-2009 10:23 PM
m.woo
07-29-2007 10:50 PM
Quick Reply: 2002 Accord: Belt squealing when starting after replacement
