Old 04-03-2015, 09:56 AM
How-Tos on this Topic
Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Interior How-tos
Print Wikipost
2000 honda accord coupe air filter replacement? and e-brake issues
Old 03-10-2009, 11:07 AM
New User
xaznxgurliex's Avatar
Post 2000 honda accord coupe air filter replacement? and e-brake issues
does anyone know how to replace the air filter? any help would be greatly appreciated!
also...my brake light stays on after i release my e-brake from parking it for more than like 4hrs. however, after running the car for a while, parking it, then releasing the e-brake, the brake light turns off. what's going on?
Old 03-10-2009, 11:17 AM
tamadrummer1120's Avatar
Default Re: 2000 honda accord coupe air filter replacement? and e-brake issues
For the e-brake deal, check the fluid level in master cylinder. Low fluid level will set off the "BRAKE" light in the dash.
Old 03-10-2009, 04:42 PM
h0p3l355dork's Avatar
replacing an air filter is actually really easy. Just look for the air filter cover which should be on the right side of the car (while looking at the car under the hood) It is just in front of the drivers side above the front left wheel of you car. It should also be right next to your battery. There will be four screws on the cover. Unscrew these four screws and pull the cover off.. Take out old filter and put in new one and you are good to go.
I've included a diagram to help you out.
The cover is labeled number 1 and the 4 screws you need to take out are # 16. If you need any more help just post again.
Old 03-10-2009, 06:07 PM
redbull-1's Avatar
Most of the info. is in the owner's manual:
If it is a 4 cylinder, the air filter cover can be open by unsnapping the four clamps, for 6 cylinder, loosen the bolts. (See pictures.)
Check brake fluid level first for the brake light. Otherwise, it just might be a sticking float or the master cylinder reservoir filter might need to be replaced; see link.
http://www.tegger.com/hondafaq/tsb/accord/x03-078e.pdf
maxi15
12-21-2007 10:56 PM
clapton924
07-21-2007 09:22 PM
White_EK49
Honda S2000
09-10-2005 01:14 AM
cplatt
04-12-2005 03:42 PM
Shadow Racer
09-21-2003 11:16 PM
Quick Reply: 2000 honda accord coupe air filter replacement? and e-brake issues
