VSS Signal Comparision
Old 11-11-2013, 08:15 AM
afnan's Avatar
Icon2 VSS Signal Comparision
I read on the internet that 92 accord VSS Sensor has three wires.
+12 V Yellow
Signal (normally at 5V) Orange
Ground Black
When the car moves signal becomes the 5v pulses ranging from Ground to 5V.
My question is that is there any difference in the VSS signal of 98 accord automatic transmission ? is it same and works on same mechanism ?
Old 11-11-2013, 08:38 AM
spAdam's Avatar
Default Re: VSS Signal Comparision
Check that voltage. I would imagine it to be the same as the Civic/integra ones of the same generations. They are 0-12V pulse, which makes more sense than the VSS having some sort of voltage divider within it (ie if it outputs a 5V pulse you would feed it 5V).
You should be able to get all of this form the service manual.
Old 11-11-2013, 08:45 AM
afnan's Avatar
This page says what i am saying. http://techauto.awardspace.com/vss.html#Solutions Actually your point is legitimate
Joel Diaz
10-12-2018 12:45 PM
bokamper17
07-10-2009 01:29 PM
1accord
07-28-2006 12:04 AM
91t4
06-27-2006 12:30 AM
HamiltonRex
02-13-2005 06:29 PM
Quick Reply: VSS Signal Comparision
