MP1A swap for MPXA?
Old 09-10-2009, 06:08 PM
coldje's Avatar
Icon2 MP1A swap for MPXA?
I've been told a JDM MP1A out of a '94+ Accord auto tranny will replace a '90-93 Accord MXPA or APX4 tranny. Has anyone done this? Are there any things to watch for besides using the flex plate and torque converter that come with the MP1A? Will the existing TCU work?
Old 12-19-2012, 03:38 PM
your friend's Avatar
Default Re: MP1A swap for MPXA?
Yes, it will bolt on. and work.
Old 12-19-2012, 04:25 PM
MM Gruppe B
MAD_MIKE's Avatar
Everything will work fine.
The two main things to look out for are that the seals for the axles on the differential are not damaged, and that the cooler hard lines for the transmission are not bent/kinked. I had to reuse the existing cooler lines from the car as the import trans lines had been damaged, you will need four new crush washers from Honda. These need to be changed while the transmission is out of the car.
edgar andrade
Transmission & Drivetrain
09-26-2017 12:31 AM
Nick_cg1
09-12-2012 03:56 PM
DarkLamp
10-28-2007 05:34 PM
Dmata
04-22-2004 07:43 AM
Quick Reply: MP1A swap for MPXA?
