2.3 Vtec carbon deposit removal
Old 03-10-2011, 09:29 PM
shortlid's Avatar
Icon2 2.3 Vtec carbon deposit removal
Ok, my '99 Accord EX sedan in Manual has 170,000 on the clock. When I replaced the Denso plugs that I put in it 30k ago they were real worn. The car has started consuming oil at about a qt every 3,000 miles. When I replaced the plugs when I looked with a light down into the cylinders it looked like flakey, black, heavy carbon deposits. I am thinking maybe the pistion rings are stuck with carbon and need to clean out the upper engine.
Should I just suck Seafoam into one intake with one of the vacume lines while the car is running. Or should I pull the new NGK plugs I just put in it and use DEEP CREEP or Marvel Mystery Oil in each of the cylinders as well to help maybe unstick the piston rings?
Old 03-11-2011, 12:12 AM
holmesnmanny's Avatar
Default Re: 2.3 Vtec carbon deposit removal
1 quart every 3,000 miles isn't bad. The carbon on the plugs could be from your oxygen sensor needing replacing as its pumping too much fuel.
Old 03-11-2011, 06:46 AM
InvaderTrax's Avatar
Mopar Combustion Chamber Cleaner. He's using two cans on a V8, so one can should be enough for your car. The big difference here is that this stuff foams, and Deep Creep doesn't
http://www.mallcrawlin.com/forum/showthread.php?t=3055
Old 03-11-2011, 10:42 AM
Blazin Si's Avatar
If you already have a bottle of seafoam, give it a try. That stuff never made any difference in my motors. I've had better results with spraying a mist of hot water into the throttle body.
s13hero
12-27-2011 01:38 AM
ONYX S-13
01-25-2010 03:49 PM
.Ry
10-24-2005 09:20 PM
mikester_91
03-08-2005 06:18 AM
bubbajim
02-19-2004 06:36 PM
Quick Reply: 2.3 Vtec carbon deposit removal
