Brake Pedal LOW
Old 09-19-2008, 03:19 PM
kornerk12's Avatar
Default Brake Pedal LOW
This is ok an 1995 Accord LX Sedan w/o abs and rear drums. The car creeps forward and lights and the pedal will drop down. THe pedal is always low with the car on or off. After taking a look at itive bleed the brakes, checked for leaks, checked brake fluid level, and done the tests shown in the helms. I ended up changing my master cylinder the pedal feel firmer, doesnt sink and the car wont creep forward anymore. However the pedal is still low but only with the car on. When the car is off it will be perfectly fine. The car seems to brake fine also, just a low pedal.
Old 09-19-2008, 06:26 PM
hon2984's Avatar
Default Re: Brake Pedal LOW (kornerk12)
i don't know what u mean by low. I would check and bleed everything again, check the vacuum line. did you bench bleed the master cylinder? maybe for some reason you got a similar master cylinder with a different amount of piston travel.
Coomer
05-21-2008 04:39 PM
atmdc
21
04-11-2007 07:06 AM
JZA70
11-14-2006 11:16 AM
Jinya1004
13
07-03-2004 01:48 PM
Draco
02-12-2003 04:24 AM
Quick Reply: Brake Pedal LOW
