Trunk Floor Sound Deadner
Old 12-10-2007, 11:52 PM
JohnD1079's Avatar
Default Trunk Floor Sound Deadner
That **** that you guys scrape off of the floor and trunk to save weight, its job is to insualte sound.
What is this stuff called, and where do you get it from?
Old 12-11-2007, 03:15 AM
H-T Order of Merit
TouringAccord's Avatar
Default Re: Trunk Floor Sound Deadner (JohnD1079)
I don't know what you would call the stock stuff other than sound deadening material but people serious about audio use stuff like Dynomat and other products that are similar.
Maybe you would get a better response from the A/V/S forum.
Old 12-11-2007, 07:37 AM
He knows where you live!
TheMuffinMan's Avatar
It's essentially a tar compound.
If you want to replace it you've got a few options.
Dynamat Xtreme works well but is a complete bitch to remove (personal experience)
Breadboard (cheaper version of dynamat)
Roofing tar (sheets of actual asphalt/tar you roll in, smell goes away after about a week)
Do some googling and you can find a lot.
Old 12-11-2007, 05:11 PM
JohnD1079's Avatar
Default Re: (TheMuffinMan)
well im not asking to find a cheaper version of dynamat.
A while back when the connection at my Fuel Sending unit(pump) was lose, instead of dropping the tank, we just cut the sheet metal to access it. I heard about the Tar crap you roll on. I will probably try that.
Old 12-12-2007, 12:39 AM
ate my pixel
Twixle's Avatar
Default Re: (JohnD1079)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JohnD1079 &raquo;</TD></TR><TR><TD CLASS="quote">well im not asking to find a cheaper version of dynamat.
A while back when the connection at my Fuel Sending unit(pump) was lose, instead of dropping the tank, we just cut the sheet metal to access it. I heard about the Tar crap you roll on. I will probably try that. </TD></TR></TABLE>
Cutting near the gas tank, great idea.
BlackJacket
10
11-11-2013 02:33 PM
:jdmshmaydm:
08-03-2004 05:02 AM
Steve91
18
05-29-2002 06:38 AM
boomslang
09-29-2001 01:05 PM
raene
06-06-2001 08:25 AM
Quick Reply: Trunk Floor Sound Deadner
