1996 honda accord lx turn signal problem
Old 10-07-2011, 05:23 PM
jonathan18's Avatar
Icon2 1996 honda accord lx turn signal problem
My turn signals don't work and don't light up on my dash board my hazard lights DO work and light up on the dash board...my tail lights nd brake lights work too everything is all good except that...I got a new flasher fuse that wasn't the problem it still didn't work my bulbs are new so that isn't the problem either I have no idea what else to do
Old 10-07-2011, 05:55 PM
CDelgado220's Avatar
Default Re: 1996 honda accord lx turn signal problem
Flasher relay?
Old 10-07-2011, 06:19 PM
jonathan18's Avatar
I try to replace the flasher relay its a black box right? That's what I meant by flasher fuse but that still didn't fix the problem when I turn the turn signal switch it turns my headlights on perfectly and my high beam works too but then when I try the turn signals nothing happens
Old 10-08-2011, 12:35 PM
What relay did you get? Make sure it's the correct one
wait... why would you mention your headlights?
Anyway.. I think you might be talking about the corner lights next to the headlights, if you are they are not turn signals. There are turn signals on your bumper by the lower grill on either side, those are your turn signals.
If you're actually talking about the bumper/turn signals. Have you tried the actually fuses?
Old 10-08-2011, 07:58 PM
jonathan18's Avatar
I'm saying that I tried to see if it was the switch that's messed up but it turns my headlights and high beams on but when it comes to pulling it down nd pushing it up for the turn signals nothing happens not even on the dash board the green arrows light up but the thing that got me confused is my taillights work brake lights work and warning lights work except my signal lights which are suppose to flash they don't at all all my fuses are good and yea I got the right flasher relay but it still didn't fix the problem
Old 10-08-2011, 08:02 PM
jonathan18's Avatar
Its black little box that is connected under the dash board on the driver side by the brake pedal to the left bunch of fuses and stuff I checked to see if it was the one that said flasher on it I got a new one same exact one but didn't fix the problem
Old 10-08-2011, 08:21 PM
lazlong's Avatar
It's probably your combination switch. number 16: http://www.hondapartscheap.com/south...t=0&quantity=0 It's the same part for the 2 or 4 door.
Old 10-09-2011, 03:37 AM
jonathan18's Avatar
You talking about the turn signal swtich right that turns on the headlights and turn signals on?
Old 10-09-2011, 04:43 AM
lazlong's Avatar
^^ yes
techsupport
02-13-2017 08:09 AM
Emily2809
06-04-2013 06:30 PM
biggentplayer
12-19-2006 10:28 AM
Quick Reply: 1996 honda accord lx turn signal problem
