1994 Honda accord doesn't work
Old 02-25-2017, 07:58 PM
HondaGal94's Avatar
Default 1994 Honda accord doesn't work
Hello my 1994 lx accord was driving smooth two days after I brought it I noticed the d4 light was blinking I had to tap starter to work a few times to work. Next day it just kept cranking like it wanted to start but doesn't so I changed the distributor twice, new spark plugs. Still nothing Any Advice all it does is cranks . and yes it has spark and gas so idfk whelp.It gas the it was the distributor and spark plugs six months later the car does it again change spark plugs new distributor still cranking it seems as it Waits To start but doesnt please se video
Old 02-25-2017, 08:32 PM
ordale's Avatar
Default Re: 1994 Honda accord doesn't work
I don't know what a d4 light is but could it be your starter since you had to tap it to work. Take it off and bring it to AutoZone for a bench test.
Old 02-25-2017, 08:46 PM
HondaGal94's Avatar
D4 is Drive 4 wouldn't it not crank if starter broken it cranking thanks Again
Old 02-25-2017, 09:29 PM
holmesnmanny's Avatar
pull the valve cover and check the mechanical timing, if it's good then check compression
Old 02-25-2017, 10:22 PM
HondaGal94's Avatar
Check out the video https://youtu.be/cJYyUuinZ4k
HondaGal94's Avatar
okay will do
Old 02-25-2017, 10:57 PM
You said you have spark and fuel so you might need to check for injector pulse with a noid tester after checking the above. You can normally rent the tool from auto parts stores. My first guess still is that you may have jumped a tooth or two so checking mechanical timing will check that out first. I hope you didn't break the timing belt.
You can also check for stored codes.
Old 02-26-2017, 03:51 AM
ordale's Avatar
oh yeah that's right.
Closetgeek
12-09-2015 04:45 PM
trex352
05-24-2012 01:48 AM
johanna
10-22-2007 09:13 AM
k1ke77
07-06-2007 02:53 PM
Quick Reply: 1994 Honda accord doesn't work
