1988 Accord Carb A20A
Old 11-21-2004, 11:07 AM
Charlescox's Avatar
Default 1988 Accord Carb A20A
Start my car and it Idles at 2500 for about 2 mins. then the idle increases and when i push the gas the idle drops down to 100 rpm and the car dies. Just wondering if you could help me out and tell me what I can do to fix it. This has happened before but the car just fixed itself i guess. This started happening this time when I was parking put parking break on forgot to TAKE CAR OUT OF GEAR, released the clutch and killed it. That is when it started doing this again.
Old 11-21-2004, 07:17 PM
92 CIVIC HATCH VX's Avatar
Default Re: 1988 Accord Carb A20A (Charlescox)
bump
Old 11-22-2004, 04:18 AM
Charlescox's Avatar
confused? Driving my car to work today lost all power but it was not the alternator kind of like i lost fuel pressur. Gas pedal was to the floor and the highest the tach would go is 4000. Also tried to shut it off and it would not shut off I really don't understand please HELP
Old 11-22-2004, 07:03 AM
toughlou's Avatar
I just got rid of my carb 1986 and had a similar problem
The car would not shut off after I turned it off, kept rumbling
Also had the same problem with the hard idle
Guess what you need a new carburator.
I decided to junk the car instead a new honda carb is $700.
Old 11-22-2004, 07:38 AM
Charlescox's Avatar
BUMP
Old 11-22-2004, 12:10 PM
Charlescox's Avatar
BUMP
SOMEONE PLEASE GIVE ME SOME MORE ADVICE
Old 11-23-2004, 04:42 AM
dr_evil2005's Avatar
i had the same problem also. i checked the fuses under the hood and replaced the blown ones and recharged mt battery and it runs like it should now.
hope that helps
evil.
Old 11-28-2004, 06:39 AM
Charlescox's Avatar
Default Re: (dr_evil2005)
took car to a mechanic he said i had a whole in my carb diaphram and it was causing my choke to stay on full. Replacing the carb is costing $400-500..
thanks for all of your help guys
Rage97
08-19-2013 12:11 PM
StockDC2
03-31-2013 07:30 AM
EddiEEchung
09-30-2007 10:59 AM
blowtizzle
01-02-2005 01:41 PM
Quick Reply: 1988 Accord Carb A20A
