03 Accord Center Console Door Will Not Stay Closed
Old 03-25-2007, 05:02 PM
jsquared22's Avatar
Default 03 Accord Center Console Door Will Not Stay Closed
My '03 Accord has a problem with the front center console door not staying closed. I can close it but it will not latch and stay shut.
Before I start digging into the issue, has anyone encountered this before? Any suggestions / recommendations are certainly appreciated.
Thanks in advance!
Old 03-26-2007, 02:07 PM
Winjury's Avatar
Default Re: 03 Accord Center Console Door Will Not Stay Closed (jsquared22)
take it to the dealer. they have a simple solution to your problem.
Old 03-29-2007, 02:01 PM
jsquared22's Avatar
Default Re: 03 Accord Center Console Door Will Not Stay Closed (Winjury)
Thanks for the response.... but the dealer wants $175 for a replacement compartment door.
Just to clarify, this is the compartment located just below the radio.
Old 03-29-2007, 02:32 PM
Loco-B's Avatar
Yeah. They want $175 because of the labor that goes into putting that thing in. In fact if you feel confident enough, buy the part and do it youself. There are quite a few pieces of dash that have to come off in order to get that box out of the car!
Old 03-29-2007, 07:30 PM
jsquared22's Avatar
Default Re: 03 Accord Center Console Door Will Not Stay Closed (accordcd_7)
This was the retail price from the parts department at the dealer. This did not include labor.
Old 03-30-2007, 04:45 AM
Global Moderator
tech8's Avatar
Go call around to different dealers to see if they can fix it. I believe Honda had a Technical Service Bulletin (TSB) # 02067 regarding the Center Assembly Pocket on the 2003 Accord. (Doesn't mean they won't charge you for the fix though . )
Old 04-03-2007, 06:32 PM
killa rex's Avatar
i've fix these b4..it's just a piece of metal that's bend a bit..
Old 04-22-2007, 12:02 PM
jsquared22's Avatar
Thanks for the reply killa rex. I’ve tried to confirm they piece of metal you were referring to but cannot find it. Also, it seems as if the entire car was built around this dash compartment. ;-) I've removed a few panel / pieces and it's not completely intuitive on how to get this compartment removed so I can see what's actually broken. Any additional advice is appreciated.
Freemananana
11-10-2012 05:38 AM
dave1811
08-01-2011 04:49 PM
mugenspoongsr
10-06-2007 09:44 AM
Quick Reply: 03 Accord Center Console Door Will Not Stay Closed
