Out of fluid in the Clutch Cly.
Old 12-09-2006, 11:04 AM
cambodian's Avatar
Default Out of fluid in the Clutch Cly.
quick help..
My clutch stays to the floor.. will it spring back up when i refill the clutch cly, with brake fluid?
Old 12-09-2006, 12:00 PM
cambodian's Avatar
Default Re: Out of fluid in the Clutch Cly. (cambodian)
never mind, it works. had to pump it
Old 12-09-2006, 12:03 PM
iam7head's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cambodian &raquo;</TD></TR><TR><TD CLASS="quote">never mind, it works. had to pump it</TD></TR></TABLE>
you will still have bubble inside, it needs to be bleed out.
Old 12-09-2006, 12:05 PM
hondadude's Avatar
Go for a dash dive on the drivers side and look at where the Clutch pedal push rod goes thru the firewall; if you see leakage there it's time for a clutch master replacement.
One eyed mechanic says "it's low on fluid"
two eyed mechanic says "why is it low on fluid?"
hondapwr
19
12-21-2007 06:16 PM
shortlid
04-14-2007 09:20 AM
phantom_sol
13
09-09-2003 03:22 PM
Qwikrex
04-20-2003 03:27 PM
PatrickGSR94
12-08-2002 06:36 PM
Quick Reply: Out of fluid in the Clutch Cly.
