Reason's for ticking noise (besides needing valve adj)
Old 01-21-2004, 01:32 PM
space-tuna's Avatar
Default Reason's for ticking noise (besides needing valve adj)
I'm experiencing a light ticking noise in my engine. I thought the valves needed adjusting but I took it to Honda and it did not help. Any other reasons for a noise of this nature??
Old 01-21-2004, 01:35 PM
RacerXI's Avatar
Default Re: Reason's for ticking noise (space-tuna)
b-series?
Old 01-21-2004, 01:50 PM
platinum00's Avatar
Default Re: Reason's for ticking noise (RacerXI)
oil pump.
could not be getting oil up there
platinum
Old 01-21-2004, 01:51 PM
redboost10's Avatar
Default Re: Reason's for ticking noise (platinum00)
could be forged pistons? maybe
Old 01-21-2004, 01:57 PM
space-tuna's Avatar
I have a B series w/internals rods, pistons, blockguard, headstuds. Would forged pistons make a noise????
Old 01-21-2004, 01:58 PM
space-tuna's Avatar
It sounds like it's coming from behind the cam gears.
Old 01-21-2004, 02:03 PM
RacerXI's Avatar
My motor did the same thing a few weeks back. I suspected the LMA's, but I never truly found out where it was coming from. Does it make the sound at all rpms or only in the low range?
Old 01-21-2004, 02:08 PM
space-tuna's Avatar
What exactly is an LMA??? It makes the ticking in all RPM's What did you do about it?? Someone suggested it may be a valve seal tearing apart.
Old 01-21-2004, 03:48 PM
T-RO's Avatar
My D series is also ticking. I was told it was the rockers.
Old 01-21-2004, 03:55 PM
Johnyquest's Avatar
Default Re: (T-RO)
my DSM injectors tick like a mother ******, especially at idle. Are you sure that's not what your hearing?
Good luck.
Old 01-21-2004, 04:09 PM
jazz215's Avatar
Default Re: (T-RO)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by T-RO &raquo;</TD></TR><TR><TD CLASS="quote">My D series is also ticking. I was told it was the rockers. </TD></TR></TABLE>
my d16z6 ticks at idle too.. i cant really tell where its coming from though... only that its near the fuel rail and cam gear.
Old 01-21-2004, 05:18 PM
racinskittle's Avatar
Default Re: (jazz215)
My D16z6 ticks at idle too! Not sure why yet.
But there's worse problems from somewhere else so that's my last worry ????
Old 01-21-2004, 05:26 PM
baphomet's Avatar
Default Re: (racinskittle)
Old 01-21-2004, 05:35 PM
TravSi's Avatar
Default Re: (slashDEVslashNULL)
my d series ticks at idle also but i have an aftermarket cam and springs so i think its just noisey....
Old 01-21-2004, 06:05 PM
Mr.DC2TurBo's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by space-tuna &raquo;</TD></TR><TR><TD CLASS="quote">I have a B series w/internals rods, pistons, blockguard, headstuds. Would forged pistons make a noise????</TD></TR></TABLE>
its your pistons, I just did my internals and I'm getting the ticking too. Its noticable when u start up but after the engine warms up the sound gets softer. Did you just get it done? Make sure not to boost until u get at least 700 miles on the new motor and rev no more than 3500 rpm while breaking it in.
Old 01-21-2004, 06:37 PM
redboost10's Avatar
Default Re: Reason's for ticking noise (Mr.DC2TurBo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mr.DC2TurBo &raquo;</TD></TR><TR><TD CLASS="quote">
its your pistons, I just did my internals and I'm getting the ticking too. Its noticable when u start up but after the engine warms up the sound gets softer. Did you just get it done? Make sure not to boost until u get at least 700 miles on the new motor and rev no more than 3500 rpm while breaking it in.</TD></TR></TABLE>
ecaxtly what he said, forged pistons but once it warms up, cant notice much
Old 01-21-2004, 06:44 PM
earl's Avatar
A bad piston pin can sound like an out of adjustment valve. It will make that noise hot or cold.
Old 01-21-2004, 08:11 PM
chinners10's Avatar
i got a B series its a B18B1 96 engine..i got forged pistons.. and it ticks when its cold.. cause it needs to expand, i got Eagle rods too, and crower valves, and crower springs, oh the injectors tick also.. and B series usually has a small tick, i don't know why.. but its a small tick and thats normal, as long as its not coming from the bottom end like a DSM your ok..
Old 01-22-2004, 04:15 AM
RacerXI's Avatar
A LMA is a lost motion assembly. It's pretty much a lifter that puts pressure on the vtec lobe to keep it form rattling when it is not in use. I've heard they bind more than anything, but I have no personal experience with them.
I was also told by a shop that my motor had bent wrist pins on it, but my motor only made the sound during lower rpms (4K or below). Good luck figuring it out.
Old 01-22-2004, 07:04 AM
HybridHatchC1's Avatar
fuel injectors click
Old 01-22-2004, 07:11 AM
Prelude91siT's Avatar
i get alot of ticking noise to. it sounds like it could be my cam gears. if i could some expense ones would that help. i be thinking they r a lil unbalanced or something
Old 01-22-2004, 07:28 AM
gunslinger's Avatar
Location: Where thieves get shot in the face,, texas, usa
Default Re: (Prelude91siT)
The piston noise that your are referring to is called "Piston Slap" some engine builders build with a looser tolerance when using forged pistons in a FI motor.
That may or may not be the problem I was just letting you know what it was called
later
Old 01-22-2004, 07:45 AM
TURBO4drTypeR's Avatar
if you have billet cams the noise will never go away...but if you dont then get your rockers checked....
goodluck
Old 01-22-2004, 08:00 AM
Cole D's Avatar
Default Re: (gunslinger)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gunslinger &raquo;</TD></TR><TR><TD CLASS="quote">The piston noise that your are referring to is called "Piston Slap" some engine builders build with a looser tolerance when using forged pistons in a FI motor.
later</TD></TR></TABLE>
what builder builds a engine with loose tolerances I hope he didn't build yours the only thing I can think of that would be considered loose would be the piston ring gap(FI) other than that you want everything else spot on not loose
Old 01-22-2004, 10:13 AM
PM-Performance's Avatar
Default Re: (Barney Ruble)
its pistons to wall clearances hes referring to im sure.
both my motors witrh Je's sound like desiel motors i get paranoid, but deal with it
Quick Reply: Reason's for ticking noise (besides needing valve adj)
