OBD0 injector clips same as OBD1 clips?
Curious because I know precision injectors fit OBD1 clips but I have OBD0 D16A6. Wanna know if I can run them w/ no problems...
Thanks
Thanks
Re: OBD0 injector clips same as OBD1 clips? (Sonny)
obd1 and obd0 clips are different....you should just look into getting peak/hold injectors which is what obd0 hondas run instead of the saturated which is what is on the obd1 honda or you can modify the clips to fit on the obd1 injectors its simple (utility knife, 5 minutes and yur done) You just have to cut out the little tabs inside the clips so it will slide onto the injector, (you will see when you compare the injector to the clips on your car) it worked for me....
Re: OBD0 injector clips same as OBD1 clips? (TravSi)
The 880cc precision injectors are peak and hold I believe, so I should be good...anyone care to clarify...
BoRiCuA
07-06-2013 08:57 AM
