metal shaving in oil pan
Old 08-19-2004, 09:01 AM
DubyaAye's Avatar
Default metal shaving in oil pan
i just took off my oil pan and see some metal shavings in it that looks like glitters. what does that usually means. its a built motor.
Old 08-19-2004, 09:50 AM
krazn's Avatar
Default Re: metal shaving in oil pan (DubyaAye)
i believe copper color was bad...i remember i searched in archieved for this...
Old 08-19-2004, 09:51 AM
b18cx's Avatar
That, sir, would be bearing material. How long has this built motor been running?
Old 08-19-2004, 09:58 AM
DubyaAye's Avatar
Default Re: metal shaving in oil pan (b18cx)
the built motor has been running for almost 2ish to 3 years.
Old 08-19-2004, 10:13 AM
m R g S r's Avatar
Pull off the head and inspect the pistons, and if they look fine then it's the bearings.
Old 08-19-2004, 11:41 AM
Rod.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DubyaAye &raquo;</TD></TR><TR><TD CLASS="quote">the built motor has been running for almost 2ish to 3 years.
i thought you suppose to only see metal shaving after the first oil change on a rebuilt motor not after a couple of years
Old 08-19-2004, 12:30 PM
MaK
MaK's Avatar
A magnetic drain plug is a GOOD investment, because it keeps the metal pieces from getting circulated through the engine. Plus it's eaiser to inspect than dropping the pan.
Old 08-19-2004, 03:00 PM
R THIS's Avatar
Default Re: metal shaving in oil pan (MaK)
a little bit is normal... it should really almost stop after the first few oil changes, but there will always be a bit... do yourself a favour and get a magnetic drain plug... everytime i drop my oil in my built engine i look at the magnetic drain plug with a magnifying glass
Old 08-19-2004, 08:03 PM
DubyaAye's Avatar
Default Re: metal shaving in oil pan (R THIS)
where can i get the magnetic drain plug. the only place i know of is ebay. are the ebay ones good enough?
Old 08-19-2004, 08:05 PM
Suprdave's Avatar
pep boys or napa
Old 08-19-2004, 08:35 PM
JDMwhiteDC2's Avatar
Default Re: metal shaving in oil pan (Suprdave)
or if youve got some extra money spoon makes one...but a napa one would work fine
standbackimapro
06-20-2008 05:04 AM
Luward
10-29-2007 07:35 AM
pLaTiNumSR20
08-12-2007 01:05 PM
PORTED TOYOTA
Welding / Fabrication
08-21-2006 12:47 PM
Kimbo
04-25-2003 09:42 AM
Quick Reply: metal shaving in oil pan
