inch pounds vs foot pounds ????
Old 11-29-2004, 11:55 AM
boosted350z's Avatar
Default inch pounds vs foot pounds ????
i just reinstalled my flywheel and ended up torquing the fugging bolts to 76 "INCH" pounds instead of the correct 76 "FOOT" pounds, yet , when i double checked the torque afterwards with my Foot pound torque wrench, they were all tightened to at least 76 FOOT pounds. i don't get it.
isnt FOOT pounds alot more torque than inch pounds ???
wtf ???
Old 11-29-2004, 12:01 PM
mdpalmer's Avatar
Default Re: inch pounds vs foot pounds ???? (boosted350z)
A foot-pound is twelve times bigger than an inch-pound, as there are 12 inches in a foot (so 1 ft-lb = 12 in-lb).
Old 11-29-2004, 12:56 PM
Default Re: inch pounds vs foot pounds ???? (mdpalmer)
thats what i thought. But i tightened my flywheel bolts to 76 "INCH" pounds, yet when i checked them with my "foot" pound torque wrench, all the bolts were already at 76 "foot" pounds.
how the **** could that be ?
Old 11-29-2004, 01:54 PM
pip9's Avatar
i think both ur torque wrenchs are ft/lbs. An inch pound torque wrench is much much smaller than most ft/lbs wrenchs. Either that or one of ur torque wrenchs is way off.
Old 11-29-2004, 02:51 PM
SiRex91's Avatar
Default Re: inch pounds vs foot pounds ???? (pip9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pip9 &raquo;</TD></TR><TR><TD CLASS="quote">i think both ur torque wrenchs are ft/lbs. An inch pound torque wrench is much much smaller than most ft/lbs wrenchs. Either that or one of ur torque wrenchs is way off.</TD></TR></TABLE>
I would get both of your torque wrenches recalibrated. Don't want those flywheel bolts coming loose.
Old 11-30-2004, 10:32 AM
VTECVillain's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted350z &raquo;</TD></TR><TR><TD CLASS="quote">thats what i thought. But i tightened my flywheel bolts to 76 "INCH" pounds, yet when i checked them with my "foot" pound torque wrench, all the bolts were already at 76 "foot" pounds.
I'd say you're using 2 torque wrenches and not realizing it. There's no way you could torque down a bolt to 76 INCH LBS. and then it not move when you re-torque it to 76 FOOT LBS. because 76 INCH LBS. equates to about 6 FOOT LBS. That is if the wrenches are both working properly.
timbo74
04-06-2019 12:48 PM
killingtwobirds
09-11-2008 11:13 AM
92integracer
11-16-2006 08:51 PM
boosted350z
11-30-2004 04:55 AM
B18Redline
11-28-2004 06:52 PM
Quick Reply: inch pounds vs foot pounds ????
