HELP b16a turbo afr problem
Old 12-14-2012, 09:45 AM
slowasshatchy's Avatar
Default HELP b16a turbo afr problem
Hello Honda tech, just recently my b16 eg hatch has started running lean up in boost, it has a built block and head, 450cc injectors dyno tuned and all that stuff, walboro 255, what could the problem be, my tuner says fuel pump is probably taking a ****, also it runs 10.0 crusing and it feels like there is a little hesitation, almost like the car is off when I let off the gas then When I push the pedal back down it will cut back in, idles at 14.8 sometimes and 10.0 sometimes but always cruises at a flat 10.0... in boost (10.0 psi) it will hit 12.5 afr then jump to 14.0 and it never did this before, is it the fuel pump or a bigger problem?
Old 12-14-2012, 12:46 PM
carlos8's Avatar
Default Re: HELP b16a turbo afr problem
what kind of engine management and regulator are you running?
stop boostig the car till you fix the problem.
Old 12-14-2012, 12:55 PM
Hondata s100 and I'm not driving it
Old 12-14-2012, 01:01 PM
carlos8's Avatar
Your tuner take the fuel pressure in idle and two step? Sound to me like a stock injector
Old 12-14-2012, 01:17 PM
Doesn't have two step, not stock injectors, tuner is far away. Could it be the fuel pump as far as the leaning out in boost goes, it just started doing it, I have no cels but the battery light has been on since I got car, sometimes when cruising the cel will pop on but I just turn the car off.and.on and it goes off, and that's like once in a blue moon
Old 12-14-2012, 01:28 PM
carlos8's Avatar
ok. you have a fuel gauge and boost gauge? Your readings are the same?
if your pump went bad why the high 10's on idle and crusing.
Old 12-14-2012, 01:32 PM
Fuel gauge is on the filter tucked under intake, and my thought was the pump is on its way out not completely bad, it's read 10.0 s forever but it hasn't always leaned out up top, could it be a bad vtec solenoid?
Old 12-14-2012, 01:51 PM
carlos8's Avatar
hey for first fix your alternator or belt, the low voltage affect your injectors cycle.
what are your vtec set? May be you need a retune.
Old 12-14-2012, 02:43 PM
Its had the battery light on for 6 months and boosted just fine 11.8 - 12.2 on 10 psi and it just started doing it, but I will change my alternator in the morning
Old 12-14-2012, 02:47 PM
turbohatch96y7's Avatar
Bunch of lolz in here.
Could be your fuel pressure regulator.. clogged return line... Fuel filterr..
Old 12-14-2012, 02:50 PM
If your going to trouble shoot this do yourself a favor and buy a multimeter.
Check batt voltage with the car off. Should be at least 12 volts with the car off and 13.5 with the car on. that'll tell you if the alternators bad.
Also check your alternator signal voltage fuse in the fuse box.
Old 12-14-2012, 02:51 PM
How old is your wideband? It could also be the sensor or the gauge itself going bad..
Old 12-14-2012, 03:50 PM
95dxsir2's Avatar
put the ecu fuse back in your fuse block..(i believe it's a 5 amp). check the code and go from there. just because your battery light is coming on doesn't mean your alt. is bad. if battery voltage is low, you have low fuel volume and possibly fuel psi.
at cruising fuel demand isn't high like when in wot under load.
Old 12-14-2012, 06:08 PM
I don't get what you're saying dxsir
Old 12-14-2012, 07:21 PM
https://www.youtube.com/watch?v=VXax...e_gdata_player this shows crusing afr
Old 12-14-2012, 08:03 PM
Who is Mr Robot?
wantboost's Avatar
He's saying if you have low electrical system voltage then you'll have less fuel as the pump can't keep up at lower voltages.
Cold weather kill batteries
Old 12-15-2012, 08:23 AM
SiRCiviC94's Avatar
Map sensor is fkd
Old 12-15-2012, 10:07 AM
Lol what?^
Did you buy a meter yet?
Old 12-23-2012, 05:24 PM
blackeg's Avatar
Originally Posted by SiRCiviC94
Map sensor is fkd
no there is some validity to this possibility. ive had my gm 3bar go bad on me twice in the past 5 years and one of the symptoms was messed up afr. then again driving around on low voltage isnt a good thing either. with a healthy electrical system putting out about 14.5v cruising you could very well be in low 13s for voltage up top from the fuel pump draw.
side note: 8000 posts baby
Old 12-25-2012, 02:38 PM
dester223's Avatar
I'd guess bad map sensor also.
Rarely do I see fuel injectors stick and or a fuel pressure regulator just going to crap.
Old 12-25-2012, 04:44 PM
a1320honda's Avatar
Im in with the bad MAP. Had this recently happen on a customers car. Had a nearly new GM style 3bar. The car would start off fine and as a couple minutes would pass in driving, it would slowly start getting richer and richer till the wideband would max out at 10.0AFR just in regular driving. I would try to find another MAP sensor and throw it in just to rule the possibilty out. And i would be figuring out the battery light issue.
Old 12-25-2012, 04:57 PM
You run a shop and that's how you troubleshoot??
Old 12-25-2012, 05:03 PM
a1320honda's Avatar
No...i was just getting to the point quickly and saying thats what the problem ended up being. There were quite a few steps taken to trouble shoot the fuel system and other things. But how nice of you to jump to conclusions lol. Merry Christmas!
Old 12-25-2012, 05:20 PM
PhilStubbs's Avatar
Cold be a ton of different things. First thing is to check battery voltage with the car running, calibrate your wideband, check fuel pressure and also find another tuner. I put just as much effort into normal cruising as making power. No tuner should have you cruising at 10:1.
Quick Reply: HELP b16a turbo afr problem
