Hard to get into 2nd gear from 1st-2nd shift at WOT
Old 04-26-2008, 03:36 PM
StolenTeg's Avatar
Default Hard to get into 2nd gear from 1st-2nd shift at WOT
Went to the track today and i was consistently having problem getting into 2nd gear from 1st-2nd shift. When I'm shifting from 1st to 2nd, it feel like i hit a wall but it wont go into 2nd gear, half a second later it would go in.
Now when I'm driving normally, it would go into 2nd like cake.
Edit: there are a few run where i can go from 1st to 2nd with problem
Old 04-26-2008, 03:52 PM
thorclark's Avatar
Default Re: Hard to get into 2nd gear from 1st-2nd shift at WOT (StolenTeg)
Do you have the b&m short shifter?
Old 04-26-2008, 04:03 PM
StolenTeg's Avatar
Default Re: Hard to get into 2nd gear from 1st-2nd shift at WOT (thorclark)
Nope, shifting assembly is completely stock. A poster said motor mount can causes this? im on stock motor mount with ES bushing on the two torque mount and im making decent power.
Trapping 110-115 on Lo boost and 116-120 at high boost
Old 04-26-2008, 04:10 PM
thorclark's Avatar
Now that u said the mounts it makes sense when my mount was bad i had the same problem. I always thought it was the short shifter cuz i change them out at the same time thats prolly right.
Modified by thorclark at 5:17 PM 4/26/2008
Old 04-27-2008, 05:57 AM
StolenTeg's Avatar
Bleh hopefully some stiffer mount will fix this
Old 04-27-2008, 02:56 PM
thorclark's Avatar
Yea
02K20A2Ep3
Transmission & Drivetrain
11-30-2009 10:03 AM
Championship
05-09-2008 05:18 AM
Hatchman98
03-20-2007 10:59 AM
codeh22a4
06-11-2005 07:24 AM
Quick Reply: Hard to get into 2nd gear from 1st-2nd shift at WOT
