GReddy Full Auto Turbo Timer question...
hey i had to jump start my car today since its been sitting for a while in this freezing snowy weather up here, and after i jump started it, i think my turbo timer reset to all the default settings, so now when i shut the car off, the turbo timer shuts off with it. Now i went to check on the greddy website and pulled up the manual, but i dont understand where i can get to it. It says its in "Setup mode" which i cannot find setup mode in the turbo timer. Anyone done this before with theirs? all i need to know is how to get to setup mode n ill be set.
Re: GReddy Full Auto Turbo Timer question... (B00STED Si)
Ok, well i found Setup and changed it from IG (ignition) to Acc where it should run off the timer now instead of cutting off when the ignition is cut off, and it still shuts off when i turn the car off. What else can i do? on the back of the unit it also is set to Acc...
