Garrett T3 60-1
Old 04-19-2010, 03:47 PM
  #26
BoostedBlueF22's Avatar
Default Re: Garrett T3 60-1
76 trim wheel IDK about that man. Looks like a plain old 60-1. If it had a .76 trim wheel it would be huge!!!
Old 04-19-2010, 03:50 PM
  #27
bb6guy's Avatar
Originally Posted by BoostedBlueF22
Well I'd say go on with it man mounted up and all RUN THAT THANG!!! What is the white stuff on your manifold??? Are you not running a gasket inbetween?
well i really hope its a 60-1. cuz i want BIG numbers! its high temp silicone. i splld and smeared everywhere!! ha. clumsy. yes i am running a T3 gasket
Old 04-19-2010, 03:53 PM
  #28
Thats whats up man I'm running mine on copper seal or whatever used it on my head gasket too. But you want big numbers get your hands on a 35r DISGUSTING!!!!!!! My boy had a build gsr EK hatch with one ohhhhh myy holy torque steer through 5th.
Old 04-19-2010, 03:55 PM
  #29
bb6guy's Avatar
ya i ment a 76 trim (stage 3) turbine wheel, and a 60trim compressor wheel,
Old 04-19-2010, 03:57 PM
  #30
bb6guy's Avatar
there isnt much of a difference between a 35r and a t3 60-1 is there? the compressor maps look almost the same.
Old 04-19-2010, 04:00 PM
  #31
35r's are huge!!!!!! a 60-1 to a 35r is like a can of pepsi next to a two liter of purple drank!
Old 04-19-2010, 04:06 PM
  #32
bb6guy's Avatar
Hmmm...once i get the 1000cc injectors and fuel rail/FPR. and im not happy with the Dyno numbers. then i will toss it. then pick up a GT35r
Old 04-19-2010, 04:09 PM
  #33
Send one my way too... but get block guard or sleeved up before you run that monster!
Old 04-19-2010, 04:13 PM
  #34
bb6guy's Avatar
haha...my motor is built and in my car right now
here is what is done to it:
-LS/VTEC motor
-b18a Benson sleeved block
-JE 9.5:1 low comp pistons,
-Crower Rods
-LS balanced, micro polish crank
-ARP rod bolts.
-ARP head studs
-BLue printed and balanced block
-b16 head
-itr valve train
-over-sized stainless steel valves
-port polish
-JG Turbo cams
-JG cam gears
-ITR intake manifold and throttle body.
-LS tranny
-innovative motor mounts
-Greddy Racing oil cooler
Old 04-19-2010, 04:21 PM
  #35
Drool!!!!!!!!!!!!!!!!!!!! DO THE DAMN THING THEN!
-stock fuel system
You dropped a pretty penny on machining and turbo parts but let fuel intake slip your mind and a full set up is relatively cheap compared to what you have already put down.
Old 04-19-2010, 04:24 PM
  #36
bb6guy's Avatar
-stock fuel system
you are one funny character....hahah.
i know. i fukd up on leaving the stock fuel system and getting 550's =(
Old 04-19-2010, 04:28 PM
  #37
ITs all good man not like your build can't handle the lack of fuel it's just dying for it. It wants to show you its potential but your holding it back. Your setup is ready for every bit of 500whp!
Old 04-19-2010, 05:24 PM
  #38
DRAGLS's Avatar
60-1 has a 7-bladed compressor wheel.
How do i know? I'm looking at one as i type.
Sorry, but you do not have a 60-1.
Old 04-19-2010, 05:46 PM
  #39
bb6guy's Avatar
on the hot side or cold side??
Hmmm..maybe you know what it is then?
Old 04-19-2010, 05:55 PM
  #40
BoostR41's Avatar
Ok first off a 60-1 does NOT have to have a .60 cold side. If you opt for the S cover it will be a .70 cold side.
you can get a .48, .63, or .82 hotside which the stamping will be on the exhaust housing to tell you what it is.
the 60-1 is closer to a 30R than a 35R.
I have a t3/60-1 ball bearing with a S comp cover and .63 hotside with stage 3 wheel. on 14psi you will make about 400whp on a good tune and pump gas on a built motor. It wont flow enough for 450 at that low of boost. My car was just tuned to 401whp @14psi on pump gas and 583whp spinning on the dyno at 32psi falling to 27psi at redline. I would not push a non-ball bearing that far though.
Old 04-19-2010, 06:53 PM
  #41
LightningTeg's Avatar
Please stop posting. Everything you say is wrong and hurts my brain...
Old 04-19-2010, 07:31 PM
  #42
lakahang's Avatar
lol i know the 60-1 isnt that much smaller than a 35r, and btw that turbo of yours looks like a t3t4 with a 50 trim, 60-1's usually have .70ar on the comp housing if it is a garrett
Old 04-19-2010, 08:01 PM
  #43
BoostR41's Avatar
A 60-1 with a S cover flows 61 lbs/min. With an E cover like I think is being discussed it will flow less. MAX is 575whp before it is really out of its range.
On the other hand a 35R flows 65 lbs/min and will support 650whp all day and be efficient at that HP.
So in closing the 35R is a good bit bigger than a 60-1 and will support way more power before it falls on its face
Old 04-19-2010, 09:58 PM
  #44
Moderator
TheShodan's Avatar
[QUOTE=bb6guy;42225540]so you think it is a 60-1?
anyone else agree??[/QUOTE
Nah. Looks like a T3/T04E 60 trim turbocharger. Standard 270 degree thrust bearing. honestly, for most B-series, that's just perfect. Better than the standard 60-1 package anyway. you lucked out.
Old 04-19-2010, 11:12 PM
  #45
bb6guy's Avatar
[QUOTE=TheShodan;42229843]
Ahhhh....we meet again TheShodan!! you have my respect. as on other topics you have been very informative! and i will believe you that it is a T3/T04E 60 Trim. Now for B series its perfect, but what about built b series??
you just earned some swagger points...
Old 04-19-2010, 11:19 PM
  #46
bb6guy's Avatar
Hmmm what do you guys think of the Garrett T3/67 "TE67" turbo charger? might consider selling this New Garrett T3/T04E 60 trim that i bought and buying a "TE67"
Flow is 75lb/min. T04R 67mm compressor wheel...Yummy power!! haha
Old 04-20-2010, 05:10 AM
  #47
BoostR41's Avatar
Yeah you will lose spool but it will flow enough for high numbers. The thing is if you are still on a 255lph pump and 1000's you wont have the fuel to use it to its potential
Old 04-20-2010, 12:43 PM
  #48
bb6guy's Avatar
so what do you recommend? I want to make 450whp on 15lbs
Old 04-20-2010, 02:22 PM
  #49
BoostR41's Avatar
The T3/67 will def. do what you want but you wont max the turbo out without more fuel. I would say t3/67 or a GT3567 would do 450whp on 15psi depending on the set up and tune
Old 04-20-2010, 05:56 PM
  #50
bb6guy's Avatar
Nice....so im headed down the right track. so i guess T3/67 it is... and maybe some ID 2000cc injectors would complement it.
Ummm...anyone want a Garrett T3/T04E 60trim? lol. has less than 200 miles.
Quick Reply: Garrett T3 60-1
