D-Series Guide: Budget Bottom End Build-Up
Old 11-14-2002, 07:04 AM
diego79's Avatar
Default D-Series Guide: Budget Bottom End Build-Up
I know there are many of you on this board are interested in running high boost on there SOHC and are looking for ways to strengthen their motors. This guide is simply a compilation of information I've gathered during my countless hours of surfing this board and others. This mainly focuses on a few budget minded ways of building the nottom end.
Upgraded bottom end components-
LS rods with stock SOHC pistons
LS rods can be found cheap as well as d16 pistons
Big end bore width milled to match D16 crank's rod journals. Small end bore bushed to match D16 piston's smaller pin size. The difference in big-end width is about 0.035" The pin on the LS pistons is 0.826", the pin on the D16 pistons is 0.748 You need the custom made bushing that crower sells.
Apprx Cost:
LS Rods:
Rebush set of 4 rods = $32
Custom bushings from Crower = $32
Mill the sides of the large end of the 4 rods to fit crank $35
Remove LS pistons from rods, remove Y8 pistons from rods and put Y8 pistons on LS rods $40
Total: $139
This set-up is prolly good for apprx 250-300 hp. And of course this only goes as far as your tuning.
B16a Pistons matched with non-US Supra 1G-GTE pistons
Not too much is known about this set-up but is supposedly used widely in Thailand. This is information has been gathered from Turbopanda. He sells this set-up for about 400$ https://honda-tech.com/zerothread?id=267641 This set-up will net lower compression.
If you grab a D16Y8 connecting rod, and a B16A connecting rod, and put them side by side. The D-series rods are toothpics compared to the B16A rods The Toyota pistons' height make up for the length of the rod, that's why its still usable in a D series engine
D16 pistons are 75mm. 1G-GTE supra pistons are also 75mm. B16A rods are a lot stronger than D16 rods, and can handle boost better too. The rods are modified in order to accept the Toyota pistons.
Prices per Turbopanda:
4 used pistons ($113.40) + 4 new piston rings ($46.60) + 4 connecting rods ($95) + machinework ($65) + shipping costs ($95) = $415 total.
6 used pistons ($170) + 6 new piston rings ($70) + 4 connecting rods ($95) + machinework ($65) + shipping costs ($95) = $495 total.
(shipping prices are from Thailand)
This seems to be a good set-up as the supra pistons are forged and not cast. And B16a pistons have been known to hold some good hp levels.
Stock pistons on Eagle rods
This set-up is not often used because when most people go through the trouble of replacing the connecting rods they will go ahead and get forged pistons. Thing is piston usually cost 400$ and up. So this is a deterent.
A machine shop can machine grooves into stock pistons so that can accept aftermarket clips. This will allow you to use an Eagle rod or any other aftermarket rod with a floating pin. Eagle rods - 325$
Machine work - 25-75$
Block Posting
This is a way of reinforcing the stock open deck sleeves. This is an alternative to full re-sleeving for the budget minded individual. This is best illustrated on Sonny's website (hope you don't mind sonny) http://www.muller.net/sonny/crx/
Also pictures can be found on Homemadeturbo.com of block posting
http://www.homemadeturbo.com/ZC.html
Endyn also does block posting for about 250-400$
Using aluminum studs to support the sleeves under boost conditions, this is what Larry Widmer supposedly uses on his 25psi Daily Drivin Civic. These are Alot better then controversial blockguards since they dont take away the cooling from the top of the cylinder.
I hope this proves to be useful to some of you out there.
[Modified by diego79, 4:05 PM 11/14/2002]
[Modified by diego79, 4:07 PM 11/14/2002]
Old 11-14-2002, 08:03 AM
1.8T_EG's Avatar
Default Re: D-Series Guide: Budget Bottom End Build-Up (diego79)
Old 11-14-2002, 09:31 PM
New User
psileepR's Avatar
Default Re: D-Series Guide: Budget Bottom End Build-Up (1.8T_EG)
Maybe we can open this up to sleeving and block guards. like costs and maybe peoples experiences with each.
low&slowef
01-26-2011 07:36 PM
CRX MASE
03-31-2006 09:06 PM
7thGear
04-29-2004 10:31 AM
SolidSpruce
07-22-2002 12:08 PM
Quick Reply: D-Series Guide: Budget Bottom End Build-Up
