crome and launch control?
Old 07-27-2007, 12:55 PM
the.hamburglar's Avatar
Default crome and launch control?
i cant seem to get it working. its launching on its own at 4000rpm and there is no way to change the map im using. id really like to disable it all together but i can find any way in option or anywhere in crome. id like to race tonight and i just bog at anything below a 4000rpm launch. does someone know whats going on or where i can find a plugin so i can change it. thanks
Old 07-27-2007, 01:11 PM
ragethemachine86's Avatar
Default Re: crome and launch control? (the.hamburglar)
You're saying without you having set up launch control it still has a launch rev-limit of 4k? I'm confused...
To use launch control in Crome you have to download the addExtraFeatures plug-in, which adds an option in the same tab where you change your vtec etc. What confuses me is that if you don't see this option that means it is not installed, so how do you have a 4k launch rev-limit now?
Old 07-27-2007, 01:16 PM
Default Re: crome and launch control? (ragethemachine86)
ya you got it. i have no idea how i have this. where can i download this feature so that i can change it? this is the weirdest thing ever. i have never seen the 4000k rpm lauch control before and it just revs to 4000 with the clutch in at a stop.
Old 07-27-2007, 02:32 PM
http://sourceforge.net/project...58624
download it there, unzip it into your crome folder.
in the plug-in manager remove the old addExtraFeature plug-in (i dont even know why it says it's installedbefore you isntall it) and then add the new plug-in you downloaded. Then go to PlugIns drop down menu to Enhancements and add the new plug-in to your rom and you are good to go.
btw look up the Anti-Lag thread here on HT, using Crome's launch control and retarded timing (low cam) at the launch rpm you can build boost off the line.
good luck.
Old 03-29-2008, 07:42 PM
hondapimpin420's Avatar
good info man
RyanPm
06-20-2009 05:28 AM
Kaiyoken
08-12-2008 09:26 PM
fin781
07-23-2007 08:46 PM
Vouthanack
06-15-2004 11:01 AM
Quick Reply: crome and launch control?
