Best Compression for Turbocharging a B series motor?
Old 03-25-2002, 07:45 PM
shortdahri's Avatar
Default Best Compression for Turbocharging a B series motor?
I have a 2000 GSR B18C Engine and was planning on dropping a turbo kit. If i want to maximize my power output and reliability, what would be the best compression to shoot for by changing the pistons for a turbo setup? Thanks for the help guys.
Old 03-25-2002, 07:51 PM
2000_Civic_Si's Avatar
Default Re: Best Compression for Turbocharging a B series motor? (shortdahri)
Most people run like 9.0.1 Compression ratio, but when I build my motor I plan on going with 9.2.1 Compression pistons! I guess it all depends on how much boost you are planning on running, and what mods you will have done? If you oly wanna run like 10psi. you could get away with like 9.5.1......It all depend on what your needs & wants are!
Old 03-25-2002, 07:52 PM
93B17A's Avatar
do a search and most people say between 9:1 to 9.5:1
Old 03-25-2002, 08:11 PM
racerxadam's Avatar
Default Re: Best Compression for Turbocharging a B series motor? (93B17A)
higher compression+turbo=less lag+lower boost+smaller tuning window
realistically any compression ratio is feasible its all about your goals
[Modified by racerxadam, 12:11 AM 3/26/2002]
Old 03-25-2002, 08:49 PM
BlackGSR's Avatar
Default Re: Best Compression for Turbocharging a B series motor? (racerxadam)
I'm gonna run 9.7:1.
civic-r11
03-31-2009 12:04 PM
RGSH22ACCORD
06-30-2007 08:05 PM
EM1OwnerSi
10-09-2006 12:15 PM
Quick Reply: Best Compression for Turbocharging a B series motor?
