Assistance needed: Ignition related(?)stutter b18C Turbo
#26
Re: Assistance needed: Ignition related(?)stutter b18C Turbo
pretty sure that is the case, I do not have a factory 02 only a wideband. on my closed loop tab it reads "open loop (closed loop disabled)" .
In my location I dont get much weather fluctuation its between 80-86 degrees year round, although I was kinda running a bit rich at idle last time I drove I would be willing to try this if I knew what settings to used on the closed loop tab
#27
Forgot to mention you need to select your wb input source under "closed loop advanced", typically you wire your wb to d10 eld, but select whatever one you use.
#28
thanks for the info, I already have my advanced tab set up for AFR data logging. Just need to look up voltage specs for my AEM wideband and Ill give it a try
#29
#31
#35
#39
you got me with the quality headphones
anyway, really, in the start of the video you hear the stutter. after that you hear it when it's normal.
just try to hear the VTEC, you will hear the difference..
all the pulls are in the same boost about 18psi..
#46
update** We found the problem,
we did a compression test (this is the second time) and one of the cylinders showed 40 and the others where 170.
we did chen it before and it was fine..
any way, the machine shop found 4 EX valve are bent.
and maybe 2 Intake valve that not looking so good.
i orderd a full set of new ferrea 6000.
will update when installed...
#48
Moderator
Those MSD distributors never were that good, but with an external coil, it should be ok. Not sure what to tell you at this point. You at least found the bent valves. Get a fresh set of plugs, head back to the tuner and returne completely. After that, you've got me stumped. Never had anything like that before to this extent. I'm sorry I can't be of more assistance.
#49
my MSD is with an EX coil and CDI.
changed the dizzy with a friend, same problem.
we thinking it's mite be the Injectors, maybe one of them is dripping..
will keep posted, hoping to solve this.
thx
thx
#50
What are the conditions needed for the EMS to change to a VTEC profile? My understanding is that the AEM EMS has different means of choosing when to activate variable valve control (based off of TPS/RPM/MAP). Perhaps there's a slight mismatch in the conditionals that's causing that stutter.
