Car Wont Start or Crank anymore HELP!!!!!!!!
Old 07-21-2011, 09:01 PM
Bonestock98GS's Avatar
Default Car Wont Start or Crank anymore HELP!!!!!!!!
Ok my car is finally done. I started the car up yesterday. It had leaks so I found all my leaks and fixed them. So we started it up and it cranked first try no problems. My friend noticed that it didnt sound right and actually sounded like a v8 Camming. He told me to pull all the plugs one by one to see which cylinder was not firing. So I proceeded pulling from 1 to 4. At cylinder number 4 I pulled the wire and the car cut off. Went to crank it back up and it wouldnt crank up anymore. So my friends brother came to help out and he said it was getting no spark. So I changed the Ignitor and the coil in the distributor. Went to crank it again and it caught but didnt stay on at all. So my Question is what could be wrong?
1. I have a stock MAP sensor. ECU is ran by Hondata s200 that maybe chipped for another MAP sensor. Could this be why it wont Crank?
2. Is the firing order wrong?
any help would be gladly appreciated Thanks
Also Here is a video to lt you hear how it sounds and possibly tell me whats wrong with it
http://www.youtube.com/watch?v=bjvXooVrv8w
Old 07-22-2011, 05:02 AM
Default Re: Car Wont Start or Crank anymore HELP!!!!!!!!
Bump
Old 07-22-2011, 05:45 AM
rich7777's Avatar
How is your cam timing ? Does everything line up like its suppose to ?
Old 07-22-2011, 10:12 AM
I didnt check my timing yet. what should I look for when I Do check it
Old 07-22-2011, 10:27 AM
sanman000719's Avatar
crank mark is in the right spot, and the cam gears are as well this is your mechanical timing
Old 07-22-2011, 11:33 AM
Ok thanks I will go check that when I go back to the shop. And I will post and let you guys know what the results are. Thanks again. Oh and another quick questio would the timing being off cause it not to crank?
Old 07-22-2011, 02:15 PM
methodz55's Avatar
R you running another cars tune? that could be it in for results
Old 07-22-2011, 03:41 PM
Methodz yes it is another cars tune.
Old 07-22-2011, 05:45 PM
methodz55's Avatar
That might be why diff map senor prob diff inj diff motor set up that could throw it off take it to a shop/tuner
Old 07-25-2011, 02:55 PM
Update: I had another cars tune which was an ecu running s200 with boost option. It cranked once and ran really bad. My friend hooked his S300 up and the car ran smooth. So thanks very much Methodz I appreciate the help buddy
Preludelearner
03-26-2015 07:54 PM
kotehzz
05-06-2011 06:27 PM
ekeddie
07-12-2006 08:12 PM
Disco Monkey
04-04-2003 07:12 AM
Quick Reply: Car Wont Start or Crank anymore HELP!!!!!!!!
