Walbro 450 and id 1700 limit
Hi to al,I need your held for fuel set up,target is 750 to 800 whp with 6466 b18c pro 1 cams edelbrock intake,on 100ron fuel with water methanol
I have in my mind to put a walbro 450 in tank with 8an line and 6an return with 1700id injectors or fic 1650.
what do you think it is possible?maybe I should put a 044 in line or is mistake??
Please say free your opinion about brand injectors.
Re: Walbro 450 and id 1700 limit
ID1700 and the walbro 450 should be fine for that goal with your proposed setup. With 100RON and water/meth spray; I ran a 70/30 meth/water mix with 93 octane on 750cc injectors and a walbro Hellcat (525lph), near 400whp and my injector duty cycle was just over 50%.
What is your static fuel pressure ? Your duty cycle sounds a bit low for that combination.
Re: Walbro 450 and id 1700 limit update
Hi sfss as in guys
finally I will delete the stock fuel tank I will put 5 gal fcs,what do you suggest for fuel pump? Magnafuel?twin 044? Aeromotive?
JimmyCreedog
05-08-2020 10:41 PM
tnsxsear1
09-11-2004 09:01 PM
jansenrw
05-21-2003 05:46 PM
