OsideTiger 660cc Injector Battery Offset
Does anyone know what the injector battery offset should be for these injectors or how to calculate it?
Re: OsideTiger 660cc Injector Battery Offset
The 600cc oside tiger injectors I had where absolutely terrible. They were wildly inconsistent and always had a lean tip in issue no matter what was changed in my calibration. They would also randomly start giving my very lean afrs (like 3 whole points above target) after they got heat soaked. I ended up replacing them with injector nation 900cc ev14 injectors and all of my problems disappeared. I have read of multiple people have similar experiences with oside tiger injectors. Do yourself a favor and replace them with quality injectors. It will save you a lot of headaches.
But to answer your question they only provided dead times for one voltage instead of a scale like what comes with better injectors. You will need to tune the other voltage dead times yourself.
Throw them in the trash & get real injectors.
?Injector Dynamics Fuel Injectors
? Honda/Acura FIC Injectors
Yes they are THAT bad.
I'm Huge In Japan
DO NOT USE THESE. You'll destroy your engine. I've seen it first hand, they fail right out of the box half the time. I refuse to tune them anymore, they're the worst injectors on the market.
Never cut corners on fuel components, I trust nothing but Grams and ID.
beenba
05-02-2014 12:41 PM
