ITB bin file anyone?
Old 08-12-2008, 06:20 AM
darkintegra's Avatar
Default ITB bin file anyone?
Anyone have a good crome bin file for a b20/vtec with ITBs just so I can get to the tune shop?Ive searched Xenocron directory and others but found nothing.
Old 08-12-2008, 10:33 AM
GhostAccord's Avatar
Default Re: ITB bin file anyone? (darkintegra)
Are you able to monitor AFRs or do a street tune if you do happen to get someone to give you one? If not don't risk your engine and tow it!
ITB's are a tune from start-up setup. One persons bin won't always work on another. Unless you have someone that lives in your area with the same setup. If you take someones tune that lives on the coast @ sea level and your inland @ a higher elevation. Or vice versa. Their bin probably won't run so shyte hot. I would suggest a tow & tune for your ITB setup.
If you want to go on the cheap. Find a friend with a truck, toss him a few bucks for gas. rent a car dolly and off you go. A tow may still be cheaper depending on how far away your tuner is though.
Old 08-12-2008, 12:29 PM
moderator emeritus
98vtec's Avatar
read the rules
camshafted
08-26-2010 10:59 PM
lust4sound
12-28-2009 06:26 PM
gribbs
Paint and Body
11-15-2008 02:13 PM
0260MOTORSPORTS
11-28-2006 11:19 PM
ActiveAero
04-02-2004 07:28 AM
Quick Reply: ITB bin file anyone?
