First engine start of build
Old 02-11-2017, 02:50 AM
lolv8s's Avatar
Default First engine start of build
b18a1 ok so I have a walbro 255 fuel pump. Gsr oil pump. Do I just prime them both? This engine has never been cranked since my build. So honed cylinder walls. And brand new wiseco pistons and rings. And fully built head. What all do I need to do before I turn over? Do I need to oil a specific way? I wanted to pore the oil all over the valve train when I put it in. But what about the cylinders?
Old 02-11-2017, 11:20 AM
sirtef9's Avatar
Default Re: First engine start of build
Pull your fuel pump fuse and crank it till oil pressure builds, Start it there after.
Old 02-11-2017, 05:23 PM
lolv8s's Avatar
is that going to be it? I put assembly lube on everything but that was 2-3 years ago. This project is at 5 years.
Old 02-11-2017, 06:18 PM
Hysterically Calm
TomCat39's Avatar
Yes that is it, once the oil light goes off, it shows the pump is working. Crank it over a few more times after the light goes off and you now have oil in all the journals etc just like if the car was ran. Then you can give her fuel and let her rip.
Old 02-12-2017, 09:08 AM
lolv8s's Avatar
alright cool. i can just unplug the fuel pump fuse or disconnect it by the wire?
Old 02-12-2017, 03:08 PM
Hysterically Calm
TomCat39's Avatar
Being the ignoramus I am, I didn't figure out what fuse controlled the fuel pump so I just unhooked the wire from the pump.
Now, I just unhook my injectors to stop fuel from happening.
Old 02-12-2017, 11:14 PM
lolv8s's Avatar
I'm the one asking lol. So just unhook the injectors?
Old 02-13-2017, 07:33 AM
Hysterically Calm
TomCat39's Avatar
Assuming your injectors are operating properly, unhooking them will prevent fuel spray.
I also unhook both plugs from the distributor.
It's the same process I do for compression tests. No spark, no fuel.
Old 02-13-2017, 10:13 PM
lolv8s's Avatar
Icon6 Re: First engine start of build
but this will prime the block and oil pump for me?
Old 02-13-2017, 11:14 PM
Hysterically Calm
TomCat39's Avatar
Cranking the motor will do the oil pump. The oil pump is mechanically connected to the crank shaft, you spin the crank shaft you pump oil.
The reason they say to prevent the fuel pump is to prevent fuel from spraying while you are moving the pistons up and down cranking the motor to build oil pressure.
Old 02-14-2017, 03:11 PM
lolv8s's Avatar
ok so just prime the oil pump then plug the fuel pump back in and crank it up? I need to hook up my catch can first.
Old 02-14-2017, 03:29 PM
Hysterically Calm
TomCat39's Avatar
That's the way I understand it.
You want the car fully assembled or the motor at least for it's first run.
Prime the pump and motor by cranking the motor without spark and fuel, then start her up and look for leaks, purge the coolant, set ignition timing, seat the rings.
Old 02-16-2017, 09:36 AM
Premium Member
94 Civic Si's Avatar
Can you disco the main relay and accomplish the same?
Old 02-16-2017, 11:26 AM
PyroProblem's Avatar
I believe you can since it controls the fuel pump and power to the ecu (IIRC).
I pull the spark plugs too. Less resistance on the motor as your priming the oil, less draw on the battery, starter isnt working as hard. Also a good time to do a preliminary compression test. Kill 2 birds with one stone.
Old 02-16-2017, 12:38 PM
Premium Member
I like that! I will get compression test numbers to compare with my initial numbers from before the tear-down..
Old 02-19-2017, 12:53 PM
turbociv910's Avatar
dissconnect the distributor and that will stop ecu from seeing it being cranked. Just crank it over til the light goes off and a few seconds after to build pressure. then connect distributor again and crank it up
TomCat39
02-06-2015 08:47 AM
PwrdByVtec_EM1
16
09-09-2011 06:35 PM
b20eghatch
11
07-12-2010 11:24 AM
GoldLudeRay
02-10-2009 07:04 AM
951dc5
03-04-2007 06:34 PM
Quick Reply: First engine start of build
