What Cam To use W/ Precision 67/65 ???
Re: What Cam To use W/ Precision 67/65 ???
Thanks for some feedback any one else!!! i heard the turbo is to small for those cams but i was looking at them any feed back guys?
Hell im currently above 700hp with the 6765 (t3 frame turbo) on a built B series. Stock cams, stock bore.
With running a heavy spring people are snapping the cams. If that's not junk I don't know what is....
King of the One Liners
I run the t1 spec web cams, and I love them, don't really understand why you'd run anything else except price and at this level an extra couple bucks is worth it to me for peace of mind and the extra clearance I got with the webs over the pro1's.
Very seldom does a cam break no matter what company made it. But cast cams WILL break if they're setup slightly wrong...too light of spring, too much spring, coil bind and the biggest and most over looked thing, LMAs binding up on the B series cams. You have to understand when you get into over .470 valve lift and above no matters WHOS cam it is you have to check all your clearances before you stick anything else in your motor and bad mouth them. Just my .02 cents...
--Alex
--Alex
Whats your definition of a Heavy Spring? I am pretty sure a bulk majority of this site runs 100lb and under springs, I think the guys breaking the cams were the guys running 100+lb springs ... I could be wrong though and they were still very few that did, everyone breaks stuff if you think your going to build a bullet-proof car your going to be in for a wake up call.
My definition of a heavy spring is 100lb+
Nothing is bulletproof, but if you go with what the best available at the time then you can't go wrong....
I am under the assumption that we should be using the ITR LMA's with cams like the Web/T1 stage 1's, 2's, and the Skunk2 Pro 1's. If this is incorrect, is there something better? Perhaps this question is aimed at Sheepey..
lemme guess, ur answer to this will be "whats cams, share with the community so we all know" the person who broke them would like to keep keep privacy, just dont bash one company, and ride the dick of another becuase HT said so.....
