Hondata CPR
#176
Re: Hondata CPR
I'm aware of that, but if you use a resistor plug then why is it still having problems? Seems like the electronics have not been designed well if it has issues. A ferrite bead is a band-aid and distorts the signal.
#177
Re: Hondata CPR
The newer batch like the one they are selling have improved filtering. I guess the ferrite bead was left as part of the new kit.
#178
Re: Hondata CPR
alright, got a ? im getting rid of my aem. i have k series coils and a t1 cam trigger in the car now. im putting s300 in it. is there anyway to make the t1 trigger work with aem? can you use the msd signal converter and convert the t1 trigger signal going to the ecu? or is my only option to put a dis back on the car?
#179
#180
#182
Re: Hondata CPR
the part number for the Hondata recommended ones comes up under the Honda Pilot; but i'm not sure how far across the board that represents (as far as in other Honda chassis).
#184
Re: Hondata CPR
I would reccomend purchasing K series coils, adapter plate and the billet dizzy cap .
I've been busy with other things but I should have everything completed this week sometime and I will post a couple pictures of my setup.
#185
Re: Hondata CPR
I promised image(s) but this is the only one I have right now because I just got a new phone and already took parts off in the engine bay for powder coat.
I will post more images, details once I get it all back together.
Thanks to Joe @ LoCash Racing for his technical support when needed!
#191
Re: Hondata CPR
mine is in the car and running great i was experiencing some issue though on the dyne, and come to find out you better have an oem dizzy because the one i bought was junk and cuasing a TDC code every pull
#192
#195
Re: Hondata CPR
Bringing this old thread back from the dead for a minute. Hoping someone can shed some light on something for me.
I just received my CPR kit from Brandon at Blue Ridge Motorsports (great guy to deal with BTW!). I happen to have some odyssey coils laying in my toolbox that I may as well put to use If possible...
Can anyone tell me if they are running J series Odyssey coils with the CPR kit currently?
Also is there any difference other than dimensions of the different OEM Honda coils that I should be aware of? There isn't anything internally/electronically to the different coil packs that I need to worry about using odyssey coils vs k series coils is there?
Just making sure the only difference here is coil retention method and I am not going to fry anything electronically if I plug in a different coil than recommended k coils.
#196
Re: Hondata CPR
Sorry for the wasted post above but I just called Hondata and they advised any OEM Honda coil will work without issues the only differences are dimensions of the coils and how they fit you valve cover for your application.
I figured I would post what I found so that if anyone else had the same questions they would know!
g2turbo
03-13-2016 08:57 AM
