best shifter for drag racing?
Old 05-21-2007, 09:12 PM
mike93eh2's Avatar
Default best shifter for drag racing?
what shifter do you like for drag racing?
i had a cheapo apc short shifter for years and it was complete junk.
and then i switched back to oem shifter which im using right now and its not as bad as the apc one but still junk. the oem goes in gear alot smoother but its making me miss alot of gears for some reason..
Old 05-21-2007, 09:33 PM
Garcia-Racing's Avatar
Probably not the shifter if its OEM.
Old 05-21-2007, 11:04 PM
Better than steak
Arturbo's Avatar
Default Re: (Garcia-Racing)
OEM with a skunk ****.
Old 05-22-2007, 03:12 AM
Bailhatch's Avatar
Default Re: (rota92)
motor mounts?
Old 05-22-2007, 03:29 AM
mike93eh2's Avatar
Default Re: (Bailhatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bailhatch &raquo;</TD></TR><TR><TD CLASS="quote">motor mounts?</TD></TR></TABLE>
why yes i do? motor doesnt move 1/2 a millimeter.
Old 05-22-2007, 05:34 AM
CHEETAH's Avatar
Default Re: best shifter for drag racing? (mike93eh2)
the stiff shifter bushings make a world of a difference, lol Mugen sells the kit for liek 80 buks and it really does feel good.
i'm more a C's shifter with the skunk2 **** LOL ... the heavier know helps with balance ... ever pick up an FD3S shiftknob ?
Old 05-22-2007, 06:50 AM
Ginger Kid
pomansouth01's Avatar
what does everyone think about the fastline shifter??
Old 05-22-2007, 08:03 AM
I'm really 2slow
2fast4u831's Avatar
Default Re: (Arturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Arturbo &raquo;</TD></TR><TR><TD CLASS="quote">OEM with a skunk ****. </TD></TR></TABLE>
Old 05-22-2007, 09:04 AM
kmaz93da's Avatar
Hurst shifter, buddyclub knobe.
Old 05-22-2007, 01:58 PM
mike93eh2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rota92 &raquo;</TD></TR><TR><TD CLASS="quote">What mounts are you running? Just for curiosity lol</TD></TR></TABLE>
prothane on the 2 side mounts and rear tranny mount and then i window welded the a/c torque mount and also the front tranny torque mount.
still havent got a good response as to what the best shifter is.
Old 05-22-2007, 02:09 PM
ninesecrx's Avatar
Default Re: (mike93eh2)
On my old race car, I ran the stock shifter with the upgraded bushings and it worked good for me I do not think your going to get an answer on what the "best" is. Seems like this would be personal taste. Good luck with it!
Old 05-22-2007, 02:12 PM
mike93eh2's Avatar
yea i have the shifter bushings...
Old 05-22-2007, 02:13 PM
tony1's Avatar
Default Re: (ninesecrx)
I like a stock shifter best too.
It's not your stock shifter making you miss gears. It's either slop in the linkage or shifter bushings, a bad trans, or you can't drive.
Old 05-22-2007, 02:18 PM
mike93eh2's Avatar
my rebuilt tranny has been wierd lately. i didnt start missing gears (usually second) until i put the stock shifter back on and replaced the syncromesh with the new honda mtf. im starting to not like the new honda mtf water.. i think that is what is causing the problems. as soon as it warms up it doesnt like to go into gear as good. that **** was like water going in but i thought it was the best to use.
Old 05-22-2007, 05:39 PM
I used to used the Honda MTF with Lucas oil stabilizer. It seemed to work well.
Old 05-22-2007, 05:45 PM
Jared's Avatar
solid motor mounts, urethane shifter bushings, and factory gsr shifter&lt;-best evaaar
Old 05-22-2007, 06:28 PM
not so civic's Avatar
Location: gravity rides everything...everything will fall, se GA/ne FL
i like push/pull shifters with a linear pressure switch ignition cut .
Old 05-22-2007, 09:39 PM
reaction360's Avatar
same here
-zol
Old 05-22-2007, 09:43 PM
del_slow420's Avatar
im running the b&m straight shifter with energry bushings and i love it.. shifts smooth and never miss a gear
Old 05-23-2007, 01:52 AM
4doorIntegraGSR's Avatar
Default Re: (del_slow420)
i agree B&M stright with type-r **** and energy bushing
loved it more than anything about my car
friends did too
Old 05-23-2007, 02:22 AM
NooB
IT'S ME DAVID's Avatar
Default Re: (4doorIntegraGSR)
Oem Gsr shifter with a skunk2 shifter ****.
Old 05-23-2007, 02:07 PM
KevinT707's Avatar
Ebay shifter seems to work fine for me
Old 05-23-2007, 02:23 PM
MrParks's Avatar
b&m pro shifter cut down to stock throw. rock solid ...
Old 05-23-2007, 02:59 PM
mike93eh2's Avatar
does anyone like those one long *** 2 foot shifters?
Old 05-23-2007, 03:06 PM
paulzy's Avatar
I've always liked the feel of the stock dual bend integra shifter
Quick Reply: best shifter for drag racing?
