2013/ EK Drag Build
#40
Re: 2013/ EK Drag Build
Somewhat similar to my car, love the ek!
Where did you get the soft lines connected to the brake booster?
http://youtu.be/pq0_uo30bRw
I will post some dyno numbers and better pics of the interior and exterior once its all cleaned and together.
What kind of Power did you car put down on that dyno session? What kind of times have you run with your current set up?
#41
The car put down 598 to be exact, ran a 10.8 on my 3rd pass on this setup.
I need to run it some more, I think I should be able to keep it consistent at 10.4. Got kicked out because of no cage.
I am thinking about going coil on plug too. Any pros and cons to share?
#42
im thinking about the hondata traction control unit, but i have a 96 gsr and was just trying to figure out if the abs sensor hookup will be a issue?
#43
So I just bought a new fuel tank off of Locash, double inline bosch 044's, all new fuel lines and 3 Aeromotice fuel filters for the set up. That will take care of the fuel issue and allow me to max out the ID1000's at about 650whp.
#44
#46
Thought I would share some updates:
Just changed the whole fuel system with inline 044 pumps, filters and all new lines. I also swapped out my stage 4 comp clutch and replaced it with a comp clutch twin disk.
Everything should be ready to go back on the dyno.
#50
Thanks man, I picked the car up today drove home 25 miles smooth as can be even with solid mounts and the t1 shifter kit.
I am going to get some pictures of the whole car and post them up as soon as the car is washed.
Wish I could go to the track and really test it out but here in Phoenix, AZ they have closed down both of our tracks at almost the same time. The only track left is in Tucson which is about 150 miles from me which sucks just to get some track time to get the set up dailed in.
