Detailing Auto Detailing and Concours
Headlight Restoration?
Old 06-24-2015, 10:51 PM
ALDJ253's Avatar
Default Headlight Restoration?
The headlights look pretty clear, with the exception of some white spots on it. It appears as if fog is inside of the headlight, however after inspecting it, the headlights actually have white on the outside of it.
How do I get rid of this? Recommended products?
How to fix this white/foggy look?
Old 06-26-2015, 01:37 AM
Steve at Heart
Bently_Coop's Avatar
Default Re: Headlight Restoration?
I have the mothers kit and it worked pretty good. Most stores have either a hand sand kit or a drill kit. Just be prepared to mask alot of the body surrounding the headlamps off.
Old 06-29-2016, 09:37 PM
Redaccrd's Avatar
Try subbing compound but before that, try toothpaste
Old 07-17-2016, 08:06 PM
MiG-21 superfan
builthatch's Avatar
there are lots of options to remove that oxidation that vary in effectiveness. i prefer the ones that actually remove the damage instead of covering it up and also include some sort of long term protection to keep it from happening again.
the only solution i've found that works the every damn time and doesn't end up hazing again is to sand by machine (i use the Meguiars 3" foam backed sanding discs), machine compound, machine polish and then Opti-Lens coating.
there are some DIY options to coat the lens once you get the oxidation and damage removed using a witches brew that includes urethane clear coats like Minwax Spar. you can find write ups about that on detailing forums. a pro tip tho: when you think you have it as good as you want, wipe it down with a solution of 25% isopropyl alcohol and distilled water WITH THE LIGHTS on. the solution removes any things from the process that could be temporarily filling scratches and the lights will highlight the scratches by default.
Old 01-02-2017, 09:44 AM
Honda2004's Avatar
All depends on how much oxidation their is, yours dosn't seem to bad. Should be an easier fix.
I agree with builthatch, a good sanding is neccessary with a very fine grit, polish & coat. Will be like new again.
Experience - Machinist at tool shop
Old 08-14-2017, 09:08 AM
4thGenPrelude's Avatar
You could try one of these Headlight Restoration Kits.
Looks like they have a little tutorial on how to use them as well.
You could also just pick up some 2500 & 3000 grit sandpaper, wetsand them, and then use a cutting/polishing compound to remove the oxidation.
krzeduckii
Lighting
11-13-2008 05:36 PM
snapper1978
09-23-2006 04:22 AM
zhuman06
Honda Civic (2001 - 2005)
06-20-2006 11:47 PM
deeweezy187
03-04-2005 07:38 AM
Quick Reply: Headlight Restoration?
