Detailing Auto Detailing and Concours
DIY: Headlight Restoration
Old 03-02-2016, 11:49 AM
reddcliffe's Avatar
Default DIY: Headlight Restoration
Headlight Restoration:
In this DIY, we will be to removing the oxidation and faded plastic from the headlight and restoring the headlight to a crisp and clear gloss for better visibly at night and overall presence of your automobile.
Here, I listed some products that you would be able to find at your local department store that you could produce the same results as a professional detailing shop could produce. But of course professional grade products are unmatched, so feel free to use the compounds and products that you think might suit best for the job.
Materials Needed:
Spay Bottle filled with Water
2500 grit Sandpaper
3500 grit Sandpaper
Painter’s Tape
Microfiber Cloths
Paper Towels
All Purpose Cleaner
Simple green all-purpose; cleaner 32oz bottle [PRICE is per BOTTLE]: Multipurpose Cleaners: Amazon.com: Industrial & Scientific Simple green all-purpose; cleaner 32oz bottle [PRICE is per BOTTLE]: Multipurpose Cleaners: Amazon.com: Industrial & Scientific
Applicator Pads
Amazon.com: Chemical Guys BUFX202 Hex-Logic Polishing Hand Applicator Pad, White - 3 in. x 6 in. x 1 in.: Automotive Amazon.com: Chemical Guys BUFX202 Hex-Logic Polishing Hand Applicator Pad, White - 3 in. x 6 in. x 1 in.: Automotive
Hex-Logic (orange medium cutting)
Hex-Logic (white polishing)
Hex-Logic (black finishing)
Polishing Compound
Meguiar's Ultimate Compound
Amazon.com: Meguiar's G17216 Ultimate Compound - 15.2 oz.: Automotive Amazon.com: Meguiar's G17216 Ultimate Compound - 15.2 oz.: Automotive
Wolfgang Uber Compound
Amazon.com: Wolfgang Uber Compound 3.0 8 oz.: Automotive Amazon.com: Wolfgang Uber Compound 3.0 8 oz.: Automotive
Chemical Guys V34 Optical Grade Hybrid Compound
Amazon.com: Chemical Guys GAPV3416 V34 Optical Grade Hybrid Compound - 16 oz.: Automotive Amazon.com: Chemical Guys GAPV3416 V34 Optical Grade Hybrid Compound - 16 oz.: Automotive
Cutting Polish Compound:
Meguiar's Mirror Glaze Ultra-Cut Compound
Amazon.com: Meguiar's M105 Mirror Glaze Ultra-Cut Compound - 8 oz.: Automotive Amazon.com: Meguiar's M105 Mirror Glaze Ultra-Cut Compound - 8 oz.: Automotive
Chemical Guys V36 Optical Grade Cutting Polish
Amazon.com: Chemical Guys GAPV3616 V36 Optical Grade Cutting Polish - 16 oz.: Automotive Amazon.com: Chemical Guys GAPV3616 V36 Optical Grade Cutting Polish - 16 oz.: Automotive
Finishing Polish Compound:
Meguiar's Mirror Glaze Ultra Finishing Polish
Amazon.com: Meguiar's M205 Mirror Glaze Ultra Finishing Polish - 8 oz.: Automotive Amazon.com: Meguiar's M205 Mirror Glaze Ultra Finishing Polish - 8 oz.: Automotive
Wolfgang Finishing Glaze
Amazon.com: 8oz. Wolfgang Finishing Glaze 3.0: Automotive Amazon.com: 8oz. Wolfgang Finishing Glaze 3.0: Automotive
Chemical Guys V38 Optical Grade Final Polish
Amazon.com: Chemical Guys GAPV3816 V38 Optical Grade Final Polish - 16 oz.: Automotive Amazon.com: Chemical Guys GAPV3816 V38 Optical Grade Final Polish - 16 oz.: Automotive
Sealant:
Meguiar's Headlight Protectant
Amazon.com: Meguiar's G17110 Headlight Protectant - 10 oz.: Automotive Amazon.com: Meguiar's G17110 Headlight Protectant - 10 oz.: Automotive
Chemical Guys JetSeal Anti-Corrosion Sealant and Paint Protectant
Amazon.com: Chemical Guys WAC11816 JetSeal Anti-Corrosion Sealant and Paint Protectant - 16 oz.: Automotive Amazon.com: Chemical Guys WAC11816 JetSeal Anti-Corrosion Sealant and Paint Protectant - 16 oz.: Automotive
Microfiber Sponge Applicator
Amazon.com: Chemical Guys MIC29208 Premium Grade Microfiber Applicators (Pack of 8): Automotive Amazon.com: Chemical Guys MIC29208 Premium Grade Microfiber Applicators (Pack of 8): Automotive
The Process:
Step 1:
Spay some of that all purpose cleaner on the surface of the headlight. I like to use Simple Green, which can be found in almost all local stores. This is to clean the surface of the headlight to remove any type of material, such as dirt and debris that will interfere with the sanding process. Then wipe it dry with some towels.
At this point your headlight will still be cloudy and hazy, but don’t worry.
Step 2:
Take your painter’s take and tape up the surrounding area of your headlight to protect your paint. This will give your paint protection from the sanding that we will soon be doing.
Step 3:
Start off by taking your 2500 grit sand paper and spay bottle filled with water. First wet the 2500 grit sandpaper by giving it a few squirts. Using water as a lubricant, generously spray the area that you are sanding at the same time as you are doing the sanding in a one direction motion. Remember to keep the surface lubricated with the water in the spay bottle as you are sanding. You don’t want to apply too much pressure while sanding, but just enough to brush off the outer layer of debris. Using a sanding block as an applicator to the 2500 grit sandpaper is not required but would be helpful in evening the pressure applied.
Once finished sanding the whole headlight with the 2500 grit sandpaper, wipe it dry with a microfiber towel.
Step 4:
Now, we want to make our headlight surface even smoother. To do this we will now use the 3500 grit sandpaper. Same process as before with the 2500 grit sandpaper, using water as a lubricant, generously spray the area that you are sanding at the same time as you are doing the sanding in a one direction motion. Remember to keep the surface lubricated with the water in the spay bottle as you are sanding.
Once finished sanding the whole headlight with the 3500 grit sandpaper, wipe it dry with a microfiber towel.
Now we are ready for the polishing and sealing.
Step 5:
From here on, we will either be polishing by machine or by hand. For those working from home and don’t really have a need for a DA polisher, both methods work towards the same result. Though using a DA polisher isn’t required, it does come in handy in the process. If you are not using a DA polisher and doing a head light restoration by hand, it’s just going to take a little more time and elbow grease. When working on headlights, I like to do it by hand, I just feel in the tight space, I have more control to the areas that I am working on.
I find that Hex-Logic Applicator Pads or Hex-Logic Hand Applicator Pads work great for me.
Start off by taking some polishing compound (Wolfgang Uber Compound OR Meguiar's Ultimate Compound OR Chemical Guys V34) and applying it to the orange medium cutting pad. Just a few jellybean sized drops of polishing compound is sufficient.
Lightly spread the polishing compound by touching the headlight surface gently and moving the orange applicator pad back and forth. Then, in a small circular motion, apply more pressure and begin polishing. I like to do a 4 or 5 passes of the whole headlight using the polishing compound to make sure I get an even finish.
Once finished with this step, wipe the headlight with a microfiber tower and inspect the surface. As you can see, your headlights will receive a dramatic improving in clarity, but we’re not done yet.
Step 6:
Many of you might find this step to be extra and unnecessary. I like to work in a structural and methodical manner and I like to add in this extra layer of polish. Here we will be using either (Meguiar's Mirror Glaze Ultra-Cut Compound OR Chemical Guys V36 Optical Grade Cutting Polish) and applying it to the white polishing pad. Just a few jellybean sized drops of polishing compound is sufficient. Products in “Step 5” (Meguiar's Ultimate Compound or Wolfgang Uber Compound) work well as a cutter as well. But here in this step, we will be using the white polishing pad as an applicator.
Again, lightly spread the cutting polish compound by touching the headlight surface gently and moving the orange applicator pad back and forth. Then, in a small circular motion, apply more pressure and begin polishing. I like to do a 4 or 5 passes of the whole headlight using the cutting polish compound to make sure I get an even finish.
Step 7:
In this final step of polishing, we will be using a finishing polish compound on the black finishing applicator pad. Here, the compound that we could use are (Meguiar's Mirror Glaze Ultra Finishing Polish OR Wolfgang Finishing Glaze OR Chemical Guys V38 Optical Grade Final Polish).
Again, just a few jellybean sized drops of polishing compound is sufficient. Lightly spread the finishing polish compound by touching the headlight surface gently and moving the orange applicator pad back and forth. Then, in a small circular motion, apply more pressure and begin polishing. I like to do a 4 or 5 passes of the whole headlight using the finishing polish compound to make sure I get an even finish.
Once finished with this step, wipe the headlight with a microfiber tower and inspect the surface. Here the headlight should look amazing brand new. Now we can go ahead and apply a protective layer to your headlights.
Step 8:
In applying a protective later will prevent and discoloration, fading, and deteriorating to your headlight, which will happen when exposed to the sun.
In this step, we will apply a few drops of sealant (Meguiar's Headlight Protectant
OR Chemical Guys JetSeal Anti-Corrosion Sealant and Paint Protectant) onto your microfiber sponge applicator and spread a thin layer onto your headlight evenly.
Wait 15-20 minutes for the sealant to dry.
Now we can wipe down the headlight with a microfiber tower of any excess product and we’re done. Sealant might need to be reapplied every few months or so, depending on your product.
Keeping your headlights in crystal clear condition is extremely important, not only in preserving the value of your car and making it look good, but for driving and road safety. Crystal clear headlights equals better visibility on the road, especially in low light conditions.
Enjoy.
Old 08-18-2016, 03:30 PM
GDD Member
slomofo's Avatar
Default Re: DIY
I like how this thread has no pics.
Old 08-25-2016, 04:16 PM
pogeeboy27's Avatar
Default Re: DIY
I hate words. I learn by pics and nothing else. Please post pics op.
aaronfunstuff
14
02-24-2014 02:27 PM
crvsam
08-14-2008 08:29 PM
Volcom
01-03-2008 10:47 AM
Spoogen_1
08-11-2005 10:09 AM
98civicR
12
11-04-2002 06:10 PM
Quick Reply: DIY: Headlight Restoration
