Tial, Innovate, Aeromotive, K20a2, Wavetrac, Wiseco, Intercooler, BOV, Wastegate, Competition
PRICES UPDATED AND OBO UPDATE: EVERYTHING HAS BEEN TAKEN OUT OF CAR AND READY TO BE PICKED UP!
Here is a list of parts I have for sale:
<U>TURBO STUFF:</U>
GSR motor
Darton Sleeves
Wiseco Pistons 84.5mm
8:1 Turbo Compression
Eagle Rods
ACL bearings
Arp main studs
Arp head studs
Will give you OEM or unorthodox pulley, which ever one you want.
$2222 OBO, WILL SELL FOR 1800 BY FRIDAY, 11/14/08 AFTER THAT PRICE GOES UP TO NORMAL!
Competition clutch TWIN DISK, bought for $1275 new. No pics yet cause I haven't taken the motor out. Will let it go for ----------------$875.
30"x12"x3" intercooler, new only mounted----------$150
30"x12"x3" intercooler, used, only thing wrong is that wastegate was hitting it so a little dented in the back. Still holds boost just fine. Never had any problems with it.--------------------------------------------------$130
Tial 44mm WG... purple and silver----------------- $290 SOLD
Tial 40mm WG... silver--------------------------------$200
Tial 50mm BOV.. silver--------------------------------$150
3" aluminum intercooler piping, made to fit integra, will git EG and EK i believe, Will include all couplers and t-bolt clamps, only used for 2000 miles---$300
Hondata s300, Comes with hondata usb cable------$600
Boomslang obd2a-obd1 jumper harness-------------$75
1000cc injectors used with 2000 miles----------------$250
JG Edelbrock Intake manifold, polished!----------------$275
RPM 68mm Throttle body with all sensors-------------$200
Full-Race ramhorn manifold
B-series
40mm WG flange
T4
1600 Degree Black coating
can include 3" V-band DP, cracked but fixed, Comes with flexpipe ready for exhaust
and also dumptube can be included
$750
$900 w/downpipe
$950 w/downpipe/dumptube
Hasport EG/DC aluminum motor mounts----------- $300
BDL polished fuel rail----------------------------------$100
NEW OBX 50mm BOV silver--------------------------$140
Full-Blown dual fuelpump setup with 255 walbro pumps, -8an stainless feed, -6an return line, Aeromotive FPR w/fuel pressure gauge, Aeromotive fuel filter-----$650
Catch can setup, Has 2 lines off the back of the valve cover with a drain to the back of the block. Lines are -10an. Filter on top is a huge K&N. $300
Turbo feed and return lines------------------------$65
HKS EVC 5 Electronic boost controller, Works great, just has a 1/4" long crack at the top of the screen. Doesn't affect anything at all-----------$450
Greddy gauges, boost, EGT, and oil pressure-----$125 each
Blitz turbo timer--------------------------------------$65
New in bag Walbro 255 fuel pump-------------------$80
BOSCH 044 fuel pump, brand new never used only installed-$225
Precision 1000cc injectors used with 80 miles------------------$250
Innovate Wideband LC-1 and XD-1 gauge (needs O2 sensor)-------$225
Here is a couple pics of the setup right now:
<U> K-SERIES STUFF</U>
ATI Super Damper Pulley for Kseries-------$450
NEW k20a2 Head studs-----------------------$130
NEW AEM Fuel rail (silver)--------------------$200
NEW Wiseco 86mm and Eagle rod combo---$730
NEW K- series Wavetrac LSD---------------------$900
Civic SI K series 5 speed trans------------$600
NEW K-tuned AC & PS removal kit ----$160
Type S head with all valvetrain but not installed- $700 SOLD
Sparkks racing conversion harness--------------$250
K20a2 crank GOOD-------------------------------$250
Type R cams------------------------------------$275
Type S alternator------------------------------$150
03 k20a2 engine harness-----------------------$250
NEW Competition clutch stage 2---------------$350
type s midshaft----------------------------------$115
type s starter-------------------------------------$85
type s water pump-------------------------------$60
04 Type S fuse box---------------------------- $50
K-series K20a2 type S flywheel- RESURFACED----------$70 SOLD
K20a2 stock header---------------------------------------- $10
K20a2 power steering pump -------------------------------$40
ALPHAWERKS DC2 integra catback exhaust-----------$300 OBO
<U>B-SERIES STUFF</U>
B-series header----------------------------$50
LS CAMS, B18B1---------------------------$25
94-01 Integra radiator (have 2 of them)---$60
LS tapped oil pan -10AN welded on-------$40 SOLD
resistor box with pigtail -------------------$30
Integra lower tranny mount--------------$30
ALL SENSORS OFF obd2 ls motor.... make offer for each, iac, etc... have them all...
OBD2 Ls intake-------------------------- $30
ALL SWAP MOUNTS, $100 for set, includes, ac bracket, lower tranny mount, driver side mount, tranny mount, rear t-bracket, and rear mount.
OBD2 ls valve cover--------------------$40
OBD1 LS valve cover------------------ $20
Integra rear t-bracket----------------- $30
Stock b-series fuel rail---------------- $20
EG hatch side skirts------------------- $25 SOLD
LS obd1 engine harness--------------- $75
B-series flywheel---------------------- $20
B-series shift linkage------------------ $40
B-series half shaft---------------------- $40
Integra driver side mount------------- $20
Bseries stock clutch line, goes from firewall to tranny $15
EK condensor ---------------------------$10
LEGIT LS longblock. Needs rebuild.--- $200
obd2 b-series manual starter---------- $40
obd2 b-series power steering pump ---$30
obd2 b-series alternator ----------------$40
obd2 ls ecu ------------------------------$75
<U>RANDOM CAR PARTS</U>
DC2 Bumper support--------------------$30
part of DC2 that is under the tail lights that goes across back of car above bumper, perfecto condition, -----------$60
92-95 hatch rear bumper, black OEM, 6 out of 10 condition on paint, $25
Collector is a T3 divided. It is twin scroll and has flange welded. Bought these pieces from Straight Line Specialties for $80 unwelded and i welded it up but no need for it------------------------ $75
EBC Rotors NEW IN BOX drilled/slotted zinc anodized, found here for $123.11, the cheapest place on the net. Sold in pairs. Perfect for upgrading your stock brake rotors. $90 OBO
Will fit:
Honda Civic 1.5 DX Coupe (1993-1995) Front Kit (L/R)
Honda Civic 1.6 DX Coupe (1996-2001) Front Kit (L/R)
Honda Civic 1.6 HX Coupe (1996-2001) Front Kit (L/R)
Honda Civic 1.5 CX & DX Hatchback (1990-1995) Front Kit (L/R)
Honda Civic 1.5 Sedan (1990-1995) Front Kit (L/R)
Honda Civic 1.5 Wagon 2wd (1990-1991) Front Kit (L/R)
Honda Civic 1.6 Hatchback (1990-2000) Front Kit (L/R)
Honda Civic 1.6 Sedan (1994-2001) Front Kit (L/R)
Honda CRX 1.5 DX CRX (1990-1991) Front Kit (L/R)
Honda Del Sol 1.5 (1993-1997) Front Kit (L/R)
Honda Del Sol 1.6 (1993-1997) Front Kit (L/R)
LS Vtec oil line, NO ADAPTER, $40
Shift linkage, 94-01 integra b-series $40 SOLD
94-01 integra
LS gauge cluster, manual with 130k. $40
94-01 Integra Glove box $20
94-01 Integra Gauge cluster bezel $10
94-01 Integra Dash kicker panel under steering column $10
Modified by HickamHatch at 8:54 PM 11/13/2008
<U>TURBO STUFF:</U>
GSR motor
Darton Sleeves
Eagle Rods
ACL bearings
Arp main studs
Arp head studs
B-series
40mm WG flange
T4
$750
$900 w/downpipe
Will fit:
94-01 integra
Re: Tial, Innovate, Aeromotive, K20a2, Wavetrac, Wiseco, Intercooler, BOV, Wastegate, Competition (H
bump... EVERYTHING IS OUT OF CAR AND READY FOR A BUYER!!!
HickamHatch
12-17-2008 09:13 AM
HickamHatch
12-10-2008 05:21 PM
HickamHatch
Texas -OK -LA (Sales)
17
11-16-2008 11:55 AM
HickamHatch
11-02-2008 08:47 AM
