Inline Pro / Garrett / Tial / Neptune RTP and more...!!
Parting out my turbo setup to go K series. Selling most of it. Will ship/paypal at buyer's expense. Located in southern Indiana.
Call or Text is best (812) 374-4259
Pic of how the turbo setup looked under the hood
Action 2MS B series clutch (92-93 cable trans and 94-01 B series) Excellent condition.
$200
Garrett 60 trim w/ stg 3 wheel, .63 ar turbine housing, polished E compressor cover. Comes with fittings pictured. (Approx 3k miles on this turbo, excellent condition)
Inline Pro cast stainless manifold, custom downpipe, custom dumptube. AC COMPATIBLE! Full 3" downpipe. The piping professionally done. There is a dent in the bottom of the downpipe that is pictured. Beautiful pieces. Will not separate these 3 pieces. (o2 sensor not included. $550
Pic of when it was new approx. 3k miles ago
Dent
Manifold
Under the car/dumptube exit
Charge piping for Civic ( I had this on a 99 Si, but I believe that any 92-00 Civic/94-01 Integra should be able to utilize this piping. Piping professionally fitted and welded, IAT sensor bung (IAT sensor not included), Type S blow off valve flange. Comes with all T bolt clamps and black couplers. One knick in the 90 degree coupler that's pictured. Did not leak, not all the way through. CX Racing intercooler $250
knick in the coupler
Small dent in the bottom of the cooler, not in a bar, just the outside frame
$200
Dent
Manifold
Re: Inline Pro / Garrett / Tial / Neptune RTP and more...!!
Hi there. Let me know if you decide to sell the dumptube separately. I have the same manifold and I could definitely use it. Thanks
He wants the dumptube, I want the manifold, if you have a buyer for the downpipe you've sold it all at once! How much for the manifold and downpipe?
I'm not just hell bent on keeping it together for the sake of selling it all at once. There's no guarantee that this dumptube will work with this other guy's setup. All of this stuff was fabricated on the car. The chances of this dumptube working with someone elses downpipe and oil return setup is slim. The clearances to make this stuff fit perfectly are insane.
We have the same setup. The only difference is I have a a full rad. I'm pretty sure I can move the oil return setup around if needed. Unless this was fabricated for a half rad then it won't work.
Anyways, if you decide to sell them separately, we'll take them. Thanks
This would fit with a full radiator. The downpipe is the reason it wouldn't likely work. You can clearly see in the pics how tight of a fit everything is. If your downpipe was 1/2 left or right from where mine is at, It would not fit. The dumptube is maybe an 1/8" from the downpipe where it exits under the car. You guys want to send me money at the same time, I'll sell the dumptube for 120, and the downpipe and manifold for 440 shipped and paypal'd. I won't ship until both payments are in there, though.
As far as fitment, would this PERFECTLY FIT a precision sc61 .60 5 bolt? Any t3 5 bolt? I'm trying to weigh pros/cons of this vs. locally fabbing... I'm not really up to speed on the whole physical size and orientation of turbos....
No axial play in the turbo. Same amount of side to side that it had new, which is practically none. Turbo, wastegate, manifold, downpipe, dumptube, charge piping, and intercooler I'll do 1200 shipped. No blow off valve included. I'll also throw in oil drain line with heat wrap as well.
Will this work with a full rad? If so, How much for the turbo, oil lines, manifold, DP, DT, IC piping, intercooler and BOV shipped?
