Garrett Coolant Feed/Return Hose Fittings For BB Turbos
Old 05-14-2013, 08:07 AM
ej6sir-t's Avatar
Default Garrett Coolant Feed/Return Hose Fittings For BB Turbos
Have two 1/4npt inline hose fittings great for feeding coolant from the lower hose to a Garrett BB turbo and accepting the return of the coolant to the upper hose. I use these for my BB turbo setups I build. They are easier than welding fittings into the radiator. They are more efficient than welding fittings into the radiator because at engine speed the water pump creates a slight pressure differential between the two hoses thus forcing water through the turbo. there is no pressure differential when you feed and return from the radiator- because they are both coming from the same place. The resistance is the radiator creating a pressure diff, its simple physics, flow will take the path of least resistance. both for $50.
ej6sir-t is offline
Old 05-14-2013, 01:37 PM
ej6sir-t's Avatar
Default Re: Garrett Coolant Feed/Return Hose Fittings For BB Turbos
Forgot the pic lol.
ej6sir-t is offline
Old 05-15-2013, 07:09 AM
ej6sir-t's Avatar
bump
ej6sir-t is offline
Old 05-19-2013, 08:52 AM
ej6sir-t's Avatar
ttt
ej6sir-t is offline
Old 05-24-2013, 06:06 PM
ej6sir-t's Avatar
bump, someones building a BB turbo'd honduh
ej6sir-t is offline
Old 05-29-2013, 09:48 AM
ej6sir-t's Avatar
picture so you can see it in use
ej6sir-t is offline
Old 05-30-2013, 12:40 PM
ej6sir-t's Avatar
bumpppp
ej6sir-t is offline
Old 06-04-2013, 06:32 PM
ej6sir-t's Avatar
buy these
ej6sir-t is offline
Old 06-05-2013, 02:48 PM
SIKNASTREXO's Avatar
the ones pictured is black correct? which is the same as yours for sale
I read this on garretts website.. http://www.turbobygarrett.com/turbob...t_White_Papers
second article
FYI
SIKNASTREXO is offline
Old 06-06-2013, 07:20 PM
ej6sir-t's Avatar
second article
FYI
What are you trying to tell me?
ej6sir-t is offline
Old 04-19-2014, 09:55 AM
ej6sir-t's Avatar
Bump still forsale!
ej6sir-t is offline
Old 05-21-2016, 12:47 PM
Logan Gervais's Avatar
Originally Posted by ej6sir-t
Forgot the pic lol.
Hey man where did you buy these from might have to pick up a couple
Logan Gervais is offline
silicone-hose
08-06-2007 04:01 PM
billy hoang
01-21-2007 01:17 PM
wannakno
Acura TL, RL & ZDX
09-15-2004 06:48 PM
flip1199
09-03-2004 05:22 PM
RTW DC2R
12-16-2003 09:20 PM
Quick Reply: Garrett Coolant Feed/Return Hose Fittings For BB Turbos
