Classic Hondas All Pre-1988 Hondas.
new project 87 crx si
Old 02-04-2009, 04:42 PM
mrmcnotbuff's Avatar
Default new project 87 crx si
hey guys just wanted to post some pics of my new project!
the only thing i am missing is top bumper peice. the part that goes between the headlights and the hood. do i need a crx one or can i use a sedan or coupe? a friend checked out the junkyard for me and only found one from a hatchback!
there is a engine hoist in the back yard at my work and my boss said i can use it but i just need to get a truck to get it. then i will get the engine out of the backseat!!
also i traded a scooter for it!!!
Old 02-04-2009, 04:54 PM
NW Classic Honda's Avatar
Default Re: new project 87 crx si
Cool new project Si, good luck!
Old 02-04-2009, 04:55 PM
thank you
Old 02-04-2009, 09:44 PM
1grex's Avatar
SCORE! you suck lol. Nose has to be from a CRX. Civic noses are steel and shaped differently. If I were you I'd get a new one & reinforce it.
Old 02-05-2009, 08:26 PM
hey thanks for the info just what i needed to hear
Old 02-05-2009, 08:36 PM
got the engine hoist in the garage tonight. and took some mor pics
Old 02-05-2009, 09:01 PM
Vietnamese!
ALLxMOTOR EG's Avatar
nice GL!
Old 02-05-2009, 09:14 PM
thanks!
Old 02-06-2009, 11:20 AM
Radim's Avatar
Snaps!
Look great!
Old 02-06-2009, 03:00 PM
83 CVCC's Avatar
Sweet car. I love your license plates :p
Old 02-06-2009, 04:56 PM
hopefuly i can get crackn on it this weekend! now that i have a garage i dont have to worry about the rain
Old 02-06-2009, 04:57 PM
my license plates love u!!!
Old 02-06-2009, 07:19 PM
teamworxek9's Avatar
nice project, i always wanted to put a 2.0 pelude engine in one back in the day.
Old 12-01-2009, 03:31 PM
hey every body. this project has been on the back burner for a long time but i finaly got her goin
got the motor in the car and now im having a problem with the idle. i removed the ac and there is a vacum line that in the book needs to be plugd so i pluged it but the car will still not idle corectly. at first it would run at 2000 but now the rpm is like 3000. any ideas would be appreciated. thanks ht
i will get some pics up soon
Old 12-01-2009, 06:51 PM
E-AT_me's Avatar
try adjusting the idle air control valve on the intake manifold. if you remove the two phillips head screws you can remove the cover and then use a flat blade to tighten it down. tighten it all the way down.
Old 12-02-2009, 03:45 AM
Joseph Davis's Avatar
It's called a FIT-V, but that's the first thing I'd check, too.
Old 01-02-2010, 05:30 PM
hey thanks for ur guys help. it was the fit-v i ended up replacing it for another one. the one i had was broke on the inside.
Old 01-02-2010, 05:32 PM
i have another question.
i got the car running and it ran very well for 3 days. got the car smoged and every thing
i was being easy on it because the motor is new and all of a sudden i felt like it had no top end. the car will stop pulling around 2500 rpm. would any one know what might be up with that or were i should start lookin?
Old 01-02-2010, 07:21 PM
cbstd's Avatar
Try checking your cam timing.
Old 01-03-2010, 01:50 PM
the timing is good when i check it to the crank pulley. i think thats the same as the cam timing?
also i got a few pic i will share
Old 01-03-2010, 01:51 PM
i still need turn signals and that header pannel
Old 01-03-2010, 10:14 PM
bgangsta180's Avatar
she looks pretty good...keep it up man
Old 01-04-2010, 05:47 PM
hey i figured out what the prob was the cat was cloged. so i un cloged it with a peice of rebar lol!
Old 01-04-2010, 05:53 PM
Radim's Avatar
Looks good!
Glad to see you got it back from your uncle's.
Old 01-04-2010, 06:31 PM
Ziprock's Avatar
cool project, its coming together
Quick Reply: new project 87 crx si
