Traditional or Liquid: Sound deadening material.
Old 02-04-2007, 03:57 PM
eL
eL's Avatar
Default Traditional or Liquid: Sound deadening material.
Hey,
I was wondering which one you guys would prefer. The traditional type [dynamat] or the liquid type. I'm looking for something I can use for lowering road noise [my 06 Civic sounds horrible when riding through road salt and gravel roads] but I may install some sound equipment later on, nothing too extreme though.
I have some dynamat extreme, but I was wondering if I should use a liquid instead.
I'm pretty much a sound n00b so any info would be helpful
thanks,
-eL
Old 02-04-2007, 04:16 PM
fcm
Old Fart
fcm's Avatar
Default Re: Traditional or Liquid: Sound deadening material. (eL)
Actually a combination of both will work best, along with things like carpet underlay, "rubberized" undercoat, [spray can] and expanding foam.
As with most anything, the proper installation of the above will determine how well it works. 94
Old 02-04-2007, 05:52 PM
eL
eL's Avatar
While I'm sure you're right about the combo being better, which one works better alone?
Old 02-04-2007, 06:04 PM
fcm
Old Fart
fcm's Avatar
Default Re: (eL)
That's hard to say, I have never used just one, unless it was just a little job, for door speakers or something, it just wouldn't work very well for noise abatement.
But I guess if I had to pick it would have to be a spray product, as you can get to more places with it, and put it on as thick as you need to. 94
Old 02-07-2007, 12:23 PM
SuckMyDOHC's Avatar
while we're on the topic, what foam spray do you use?
Old 02-07-2007, 03:11 PM
tha_badguy's Avatar
if u wanna quiet down the front wheel wells
where do u spray that undercoating spray...
on the fenderliner?
Old 02-08-2007, 06:21 AM
fcm
Old Fart
fcm's Avatar
Default Re: (tha_badguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tha_badguy &raquo;</TD></TR><TR><TD CLASS="quote">if u wanna quiet down the front wheel wells
on the fenderliner?</TD></TR></TABLE> No, remove fender liner, spay "cab chassis" area, also spray kick panel "A" piller area with sound deadening spray, do NOT use under coat in the car.
I actually spray Second Skin Spectrum first then rubberized undercoat over it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuckMyDOHC &raquo;</TD></TR><TR><TD CLASS="quote">while we're on the topic, what foam spray do you use?</TD></TR></TABLE> Just about any one of them will work, I use Great Stuff from our friends at Dow chemicals, I get it at Home Depot. Caution this is EXPANDING foam it can bend sheet metal if "over used". 94
Old 02-11-2007, 09:41 AM
tha_badguy's Avatar
where can u buy second skin products online?
Old 02-12-2007, 06:27 AM
fcm
Old Fart
fcm's Avatar
http://www.google.com/search?s...audio 94
R.Storvick
17
06-07-2009 10:44 AM
ProjektR
04-27-2006 10:37 AM
Dyzee
Audio / Security / Video
02-09-2004 06:50 AM
spencedogg
03-04-2003 03:48 AM
mon2mon2
10-12-2002 07:51 PM
Quick Reply: Traditional or Liquid: Sound deadening material.
