Stereo power lock problems
my 2000 civic, radio will not work nor will the power locks. The car has an aftermarket stereo as well as an after market starter/alarm. The problems started after the car sat for awhile leaving the battery to die, I jump started it and from then on I've had these problems. I have checked all the fuses and none are blown. Anyone have any ideas?
Re: Stereo power lock problems
Take your car to a shop and have them remove the alarm system and install new one. It would be difficult to advise you here without detailed information about the aftermarket alarm system and how it was installed.
Autostart is made by Directed Electronics.
Flip your remote over and there should be a model number.(Not the one next to FCC) I should be able to locate the actual install manual, from the sound of it you have the owner's manual.
I tried completely disconnecting the alarm and trying it but the stereo and locks still did not work.
Did you find the install manual or owner's manual? Both are different from each other.
Did you check all the fuses under the hood as well? I believe there is also a backup 7.5A fuse under the hood that protects the radio, locks, A/C and I believe a few other accessory controls.
That was the first thing I checked along with every single fuse in the car just to be sure and not one is blown.
Old Fart
Do you have a stock stereo and are the stock door locks?
If the stereo is aftermarket, pull it out and check the fuse on the back of the deck
The Autostart also has inline fuses, check them.
If the power door locks are stock, will they work with the stock door lock switch or key, [central locking]? 94
Does your dome light work? If it does, when you put the switch in the middle, does it turn on/off with opening or closing the door?
