parkin light wire for ALARM
Old 12-26-2002, 10:37 PM
kHoA DoGG's Avatar
Default parkin light wire for ALARM
which wire is the color code and where can i find it for the parking light switch in a 90 crx si?
Old 12-26-2002, 10:39 PM
EG8R's Avatar
Default Re: parkin light wire for ALARM (sNoOziN' EF8)
You want your park lights to flash when the alarm is going off???
Old 12-27-2002, 05:09 AM
audioroach's Avatar
i forgot what the color was....you could remove the rear panel and probe the tail lights nah too much work. If you look in your fuse panel there is a row of male spades on top...one of those are your park light cicuit...gotta love honda
Old 12-27-2002, 08:27 AM
kHoA DoGG's Avatar
Default Re: parkin light wire for ALARM (audioroach)
right on! thanks. now my alarm will be complete.
Old 12-27-2002, 08:39 PM
95CoupinIt's Avatar
go to your dimmer switch....and use a multimeter to check it. should get +12V when parking lights are on (obviously). its either red/black or black/red...i cant remember...lol. sorry
hope this helps
Old 12-28-2002, 09:12 AM
kHoA DoGG's Avatar
Default Re: parkin light wire for ALARM (95CoupinIt)
hey thanks a lot! dimmer switch it is! but then again, i checked the voltage coming outta my alarm and there's no power there. should there be power there?
Old 12-28-2002, 09:42 AM
jwork101's Avatar
you will only have power out of the alarm when it arms. it flashes for a quick second there, unless its a negative circuit, meaning that it grounds out when armed, then you will see no power to it, its just completeing the circuit.
its the black red im pretty sure, been a long time since i opened up my column.
jim
Old 12-28-2002, 09:46 AM
chipoweredcivic's Avatar
If you are talking about parking light flash, it should supply power when you arm the alarm. If you want to add flashing parking lights when the alarm goes off, then you need to add a relay as most of the alarms supply a ground to activate other functions.
Old 12-28-2002, 06:42 PM
STK B16's Avatar
Default Re: parkin light wire for ALARM (chipoweredcivic)
parkin light wire for honda and acura is red with black stripe.
Old 12-29-2002, 02:12 AM
kHoA DoGG's Avatar
Default Re: parkin light wire for ALARM (STK B16)
this is all great, but where do i find this wire? i tried running it off the parking light fuse but that didn't work. thanks for the tips so far.
Old 01-05-2003, 09:56 AM
kHoA DoGG's Avatar
i found the red/black strip wire and tapped into it and still nothing. what kinda relay do i need? and how do i hook it up? thanks for the input ht peeps.
Old 01-05-2003, 06:49 PM
EFsleeper's Avatar
if the car is a 90 crx si there is a male blade in your fuse box that is unused that you can just plug a female spade onto to make your parking lights flash. if not its red w/ black in the drivers kickpanel. Dont go to the dimmer switch as in some cars it will only run your dash lights ( rookie mistake) cuz after all the dimmer doesnt dim your outside lights doh!
Old 01-06-2003, 06:30 PM
audioroach's Avatar
Default Re: parkin light wire for ALARM (EFsleeper)
I belive that the prob may be that the park light output for the alarm my be a ground instead of a postive.
the park light circuit needs a positive.
so get a relay spst type
wire it as such
position 86 fused 12 volt source
30 same fused source ( 7.5 amp will do fine no bigger)
85 connect alarms park light output here.
87 connect to cars park light circuit
trigger system......... if lights flash jump for joy and have a
hope this helps
Old 01-07-2003, 06:36 AM
kHoA DoGG's Avatar
tight thanks a lot audioroach. where can i get this single pole single throw reley at? will radioshack do? and wat does 7.5amps mean and where can i tap for that? thanks in advance.
Old 01-07-2003, 09:04 AM
audioroach's Avatar
yes you can get it at the shack shoulbe be about 10 bucks or less
the 7.5 amp is the fuse size to put inline with the wiring circuit.
as stated above in the crx/civic fuse panel there is a row of male pins above the fuses ign batt ( 12 vs) and park lights are all in one of those spots.
HTH
RanCRX
Audio / Security / Video
03-23-2012 08:06 PM
Ruben19
11-22-2008 08:17 PM
Black R
01-12-2006 01:03 PM
dek1mfk
08-04-2005 06:27 PM
Jer'rome
05-07-2003 10:37 AM
Quick Reply: parkin light wire for ALARM
