+5 DB or +0 DB for tweeters?
i have a set of infinity perfect 6.1 components. should i set the tweeter jumper setting on the crossover to +0 DB or +5 DB ?? what are pros and cons of each?
Re: +5 DB or +0 DB for tweeters? (noob with an RS)
Set it to what sounds best to you.
The Infinity has what some people would refer to as an aggressive tweeter. It's very detailed and pronounced IMO. If you like the tweets loud/aggressive set it to +5, then again maybe you like it the way it is. In the end it's what you like. Try each setting.
Old Fart
Re: +5 DB or +0 DB for tweeters? (t0p_sh0tta)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by t0p_sh0tta »</TD></TR><TR><TD CLASS="quote">Set it to what sounds best to you.
The Infinity has what some people would refer to as an aggressive tweeter. It's very detailed and pronounced IMO. If you like the tweets loud/aggressive set it to +5, then again maybe you like it the way it is. In the end it's what you like. Try each setting. </TD></TR></TABLE> Ditto all the above 94
Ineed$
05-25-2016 08:42 PM
