2-Way paging Clifford Matrix 12.5x
Old 11-19-2007, 12:08 PM
ninjarich2's Avatar
Default 2-Way paging Clifford Matrix 12.5x
I have the Crime Guard AU94T plugged into one of the sensor ports and when I trigger them the alarm through that sensor it doesn't always page me. But it will let me know that the vehicle has been tampered with when I disarm it. But when I trigger the other sensors ( door trigger, hood, shock sensor) that are built into the brain, the alarm pages me right away. Has anyone else experienced this? Any thoughts as to why this happens?
Old 11-19-2007, 12:15 PM
wrx-killer-Sti-eater's Avatar
Location: 99 probs but a stolen car aint 1, ca, cerritos/fullerton
Default Re: 2-Way paging Clifford Matrix 12.5x (ninjarich2)
IT has something to do with that port. Was the harness made for the dei brain? If so that port might not be working right.
Old 11-19-2007, 01:04 PM
i my honda
Global Mod
White Smoke's Avatar
Also let us know which sensor port or zone and how it is hooked up.
Old 11-19-2007, 08:46 PM
ninjarich2's Avatar
Default Re: 2-Way paging Clifford Matrix 12.5x (wrx-killer-Sti-eater)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wrx-killer-Sti-eater &raquo;</TD></TR><TR><TD CLASS="quote">IT has something to do with that port. Was the harness made for the dei brain? If so that port might not be working right.</TD></TR></TABLE>
Wow that sucks.
Yeah the plug was made for the brain. I took the extra plug from the glass break sensor and re-wired it the the AU94t (you are looking at the pins in the port, it would be Red-Black-Green-Blue). I am assuming this is how it's supposed to be wired, I copied the way the dei is wired.
Also I just tried triggering the alarm by opening the door. No page back to the remote. Just the confirmation that the door was opened when I unlock (dis-arm) the car.
Old 11-20-2007, 12:28 AM
your controler is not programmed to receive talk back from the car. Some how you de proggramed it. Hold the program button on the back of the remote till it beeps and goes in to the program mode. Press the star button. While you are at it press the unlock button too. This will turn on the amber backlight. Don't touch the controler till it exit the program mode. It will beep twice after 4-5 sec. Test it with your car and you should be good to go.
Old 11-20-2007, 12:37 AM
here you go
http://www.directeddealers.com...t.pdf
it under page notifcation. under programing
Old 11-20-2007, 05:50 PM
ninjarich2's Avatar
Ahh damit! You were right . I'm not sure how it happened but the the 2-way notification was turned off...
Thanks again
Old 11-21-2007, 12:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ninjarich2 &raquo;</TD></TR><TR><TD CLASS="quote">Ahh damit! You were right . I'm not sure how it happened but the the 2-way notification was turned off...
Thanks again </TD></TR></TABLE>
no problem.
weekendboost
Audio / Security / Video
12-11-2017 02:59 AM
szczerbanator
07-06-2010 05:54 PM
joelmatt89
08-01-2009 12:41 PM
MenaceL.A.671
03-24-2006 05:14 PM
cxSHOE
12-17-2004 03:43 PM
Quick Reply: 2-Way paging Clifford Matrix 12.5x
