Weak!EG's re-build thread.
Old 04-19-2010, 01:52 PM
Weak!EG's Avatar
Default Weak!EG's re-build thread.
Well, after a lot of thought and looking at my hatch I decided that even though it was never driven it needed a face lift to bring it up to date. The bay wasnt as flawless as I wanted it, and there are some new things I want to weld up and fabricate myself as my knowledge and ability has greatly grown since my first build.
The body of the car was far from flawless, in person it had A LOT of sanding scratches in the paint under the clear and the gold flake sat in them and showed badly in the sunlight. The 1/4 panels and doors also weren't properly blocked out so it wasn't as great as I wanted.
Now, on to the fun stuff. The car build is back in full effect and have decided to keep the "show" scene but also going to prep the car for the track as I plan on having a lot of seat time in the future. Now on to the to do list.
//Bay//
1)fill in the 7 dimples that remain where the studs used to be.
2)weld some metal in the front of the driver side mount and smooth it out.
3)cut off, and box in front lower radiator support.
4)mount remote terminals.
5)shave holes for clutch fluid res. mount and the hood prop/stay.
6)shave intake hole.
7)new brake line setup.
8)new clutch line setup.
//Interior//
1)drill center bracket for back seat mount.
2)weld all holes where seat belts, etc. used to mount and grind smooth.
3)stitch weld rear interior.
4)weld 10 point full roll cage in.
//Exterior/Other//
1)weld off door indicator switch in door jambs.
2)weld plates where rear hatch wires used to run.
3)shave license plate holes on front bumper.
4)block sand the crap out of the whole car over and over.
and after this stuff is done the whole car will be getting a fresh re-spray a new color.
Stay tuned, the work has just gotten started. Here are the last few pics taken of the car before I decided I wasnt happy with it.
this thread may move slowly at times due to the integra being built also but it will be good
Old 04-19-2010, 02:00 PM
Aaron0526's Avatar
Default Re: Weak!EG's re-build thread.
wait, how is it a re-build if you never finished the first build? lol im confused
Old 04-19-2010, 02:48 PM
Weak!EG's Avatar
The car itself was finished for the first build. I just never wasted my time putting the motor in since I wasnt happy with the body. It's being re-built with more things going on and more parts.
Old 04-19-2010, 03:07 PM
Aaron0526's Avatar
oh so basically it just didnt come out exactly how you wanted it
Old 04-20-2010, 07:08 AM
OldSkoolDa91's Avatar
found it. in for the re-build
Old 04-20-2010, 07:13 AM
1cln_eg9's Avatar
lookin mighty good to me man!
Old 04-20-2010, 10:25 AM
Weak!EG's Avatar
Okay, so after a FULL day of block sanding OVER and OVER and OVER... The doors and quarters are starting to look great and all the shiny areas are gone. Went all the way down to the original paint in some areas because the waves were so bad After the car is smooth this way, I will be throwing a coat of primer, guide coat it and block it one final time before paint.
Got the interior completely stripped for the most part.
To end the day I cut off the front lower radiator support and started to prep the car for the traction bar setup and intercooler mounting etc. Still have to finish up the passenger side. Also got started on re-doing the shaved bay
Old vs. New
Old 04-20-2010, 12:32 PM
jdmdanny7900's Avatar
im in for this one.
Old 04-20-2010, 02:15 PM
Weak!EG's Avatar
New Wilwood master cylinder and booster delete plate are on the way and I also got the fittings and line on order to do my fuel setup
Old 04-20-2010, 05:48 PM
switchjv's Avatar
man you know your bad when you have two threads for one car! JK
Old 04-20-2010, 05:54 PM
lol this is true. although i know quite well where he's coming from. i had a good start to my integra but got to the same point as him and will at some point be starting a new build thread as well. oh well, what do ya do? live n learn
Old 04-21-2010, 10:58 AM
Weak!EG's Avatar
CHASEBAYS FTW!.. ordered a wilwood master cylinder with booster delete plate for my car and a clutch line, fuel line kit for the integra yesterday around 4pm and it was here on my desk at 10am.
I'm mailing Chase my cabin harness in the morning to have it re done deleting all the ECU wiring and other un used wires since my new milspec harness goes straight to the ECU and i have a lot of things deleted.. and It will be re-sleeved in Raychem with yellow tags to complete the job
Old 04-21-2010, 01:17 PM
MLRtime's Avatar
In for updates. Can't wait to see the car finally done!
Old 04-21-2010, 02:51 PM
ckycampmember's Avatar
im down to see where this goes.
ive been following your thread since it started wayyy back on importsnc
good luck man
Old 04-21-2010, 05:39 PM
skyler84's Avatar
Old 04-22-2010, 04:47 AM
switchjv's Avatar
how much was that booster delete kit? I was on Chases web site and it wasn't listed.
Old 04-22-2010, 04:53 AM
ken9's Avatar
Where did you got your manual steering rack?
Old 04-22-2010, 06:35 AM
Weak!EG's Avatar
Chase sells the booster deletes for $225, and he has them in stock now.
As far as the rack, it came in my car. It's a CX so it had no power steering.
Spent a lot of time in the bay yesterday, got about 3/4's of it down to the bare metal to start over on my shave and do a few new things. I also mounted my remote terminals and drilled the hole for my milspec harness connector.
Derek from ALL IN FABRICATION is making me a custom catch can setup and sending me an s2k clutch master cylinder spacer plate for the car
Brand new OEM s2k cmc is on the way to go with the plate, and the car is going for some welding and media blasting in the next couple of days
Old 04-22-2010, 07:40 AM
jasoncanseeoh's Avatar
Sell me the black cover thing for the tailgate! :D
Old 04-22-2010, 07:55 AM
Weak!EG's Avatar
LOL, its still readily available at the dealership. Mine is brand new from honda, along with the rest of the interior I spent a lot of time sourcing the whole brand new interior.
Old 04-22-2010, 08:05 AM
Kyle R's Avatar
Nice
Old 04-22-2010, 10:03 AM
Price?
And I'm glad you're having a fun time with chase..... my experience..... just wasn't as great.
Old 04-22-2010, 10:13 AM
Weak!EG's Avatar
Price?
84440-SR3-003ZA , $66.29
and Chase has been a friend for a long time, PM with any issue you've had/are having and maybe we can help fix it for you
Old 04-22-2010, 10:17 AM
yeah i've never heard of anyone having any problems with chase before. i've always seen nothing but good
Old 04-22-2010, 10:36 AM
I'll PM you if I don't get my fuel line kit, that I've been waiting over a month for, today.
Quick Reply: Weak!EG's re-build thread.
