my 2008 build.....yup #4
well hello folks, yeah im back again finally making good progress on my integra once again. the plans this year are to focus on mainly the engine bay, to fix and finish all the things i left out on previous builds. the car will now be powered by a 2002 k20a2 swap which will remain stock for the most part. other mods will be a re-sprayed engine bay with all studs and brackets removed and shaved (not the whole bay). the brake lines will now be tucked away and hidden along with the battery and anything else i can either take out or hide. i have a lot of new ideas that i can now put in motion thanks to my boss John Schill (tricura on h-t) of Absolute Pro-formance who taught me the basics of welding and is helping me with this build. i built this thing before on my own and i think with help i can really step it up from the old setup.
THIS WILL NOT BE A QUICK BUILD, i am taking my sweet time to have everything 100%. i am planning on having it completed in early spring, there is no point to have it finished before then!
back in 2005:
2006 winter build:
2006 summer build:
so heres what i got so far for this year...
pre-paint, stripped
fresh paint!
shaved valve cover (-10 fitting welded on not pictured)
battery relocation
crossmember removed for lots of work to be done
this is a new one....channel cut and boxed in the crossmember for harness routing trust me on this one!
and new to this build....my work area. thanks again to John!!!
thanks everyone in advance for your support and comments
back in 2005:
2006 winter build:
2006 summer build:
pre-paint, stripped
fresh paint!
battery relocation
HRD PKR
Re: my 2008 build.....yup #4 (E-Money)
DAMN son, back again. Can't wait for these final results!
Really curious about that harness goin into the car, crossmember looks wild
Re: my 2008 build.....yup #4 (B16B_coupe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16B_coupe »</TD></TR><TR><TD CLASS="quote">
Really curious about that harness goin into the car, crossmember looks wild </TD></TR></TABLE>
yeah having a k-eg at the shop to look at really gives me ideas. i got a bunch more, if anyone thinks im crazy, i can assure you that i am indeed crazy haha
btw the valve cover, crossmember, k mount brackets and a few other things went to be powdercoated gloss black, should have that all back this week
Re: my 2008 build.....yup #4 (not so JDM Dan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by not so JDM Dan »</TD></TR><TR><TD CLASS="quote">if anyone thinks im crazy, i can assure you that i am indeed crazy haha</TD></TR></TABLE>
I'll believe it any day of the week, Dan IS fruckin' crazy!!!
**** looks like it's a goin mang. I gotta swing by the shop some time and see that fresh ta def paint work.
this car was my original inspiration for a LOT of things i did. anxious to see the next stage.
so wait. you cut a channel in the crossmember to run the wires through the channel or because you used the crossmember itself as a conduit?
HRD PKR
Re: my 2008 build.....yup #4 (g2_teg_)
Updates are coming oh my, Better not chase that flaming burger stick monkey or the chicken finger burger patrol might ketchup you
Re: (hybrid93SIvic)
thanks everyone for the support....heres some progress pics from today. still waiting on some parts to finish it all up
just need the rigid 37 degree flare tool to finish up the rears
the dash and everything is out to finish up the brake lines, all bulkheads are in place!
i wasnt sure if i was gonna post this but heres another new one....notice the bulkheads? the majority of the clutch line will be ran inside the frame. not sure if anyone has done this as of yet but heres mine
gotta run the line through then i can weld the section back up
