deschlong's restoration of a '93 Si Hatch - lots of OEM goodness
Old 08-19-2016, 11:19 AM
  #376
Premium Member
94 Civic Si's Avatar
Default Re: deschlong's restoration of a '93 Si Hatch - lots of OEM goodness
Originally Posted by deschlong
Hauled away to their final resting place last week: a farmer field/acreage in Saskatchewan belonging to my neighbour.
RIP my first-ever Civic, bought in July, 2002. A red CDM CX. Driven for 10 years and subject of many of my DIY write-ups. Converted to a VX in 2011. Next to it is the black JDM EG6 SiR-S, gutted for a bunch of its cool stuff.
These Civics will be poached for parts to restore my neighbour's (the property owner's) Frost White 1992 CDM Civic Si hatchback that we rescued from certain death at the local junkyard. So they will live on, in a sense!
I've poached the D15Z1 out of the red Civic and installed it into my blue sedan, as well as converted it to manual transmission. It was a busy few weeks! And I didn't take a single pic. Oops.
I see a 60 series Land Cruiser keeping the hatches company. Perhaps it is a diesel?
Old 08-19-2016, 11:33 AM
  #377
Premium Member
Looking forward to reading this thread, as I have a '94 Si (made in Canada) in need of some refreshing...
Old 08-21-2016, 08:52 PM
  #378
Oh look, I can change this
deschlong's Avatar
It is definitely a diesel, manual. There's about a half dozen there.
Old 10-21-2016, 07:57 PM
  #379
deschlong's Avatar
OK so I moved half-way across the country in August. About 2000km. Car performed well aside from an oil drip from somewhere. Either oil pan gasket or rear main seal. Changed the timing belt the night before I left ... yeah, I never did it when I bought the car, mainly due to lack of skill at the time. Now I realize: A. It is painfully easy. In fact, it is really difficult to **** up. This was now my third timing belt change I've done and thankfully with the right tools it gets breezier every time. B. This was clearly the first belt change the car had in 23 years. Yikes. Belt was barely hanging on.
Clutch is having minor trouble engaging ... well what I am seeing is high revs right after I shift, and then it settles down quickly. I assume this is the clutch plates not engaging right away. Maybe they're covered in oil from a rear main seal leak.
Left heated mirror wasn't functioning. Turned out it was the heater pad behind the mirror giving me problems. The connector to the printed heater element became detached. Wound up installing a brand new glass and heater element. Used my own instructions from back in 2009 ... they're still accurate!
Discovered one of the one-way valves on my headlight washers gave up the ghost. This is actually a common problem. Knowing this, I've gathered numerous one-way valves from donor Toyotas (exact same Koito part) at the junkyards. Tested them all (I had 4), all had the same problem: Basically the rubber condom that seals the valve gives out. Rubber breaks down over time, no way around it. There is no way to fix it. Well, whatever. Ordered some generic ones from China, same difference.
Old 12-26-2016, 10:16 AM
  #380
Seagull Management
94EG8's Avatar
Rear main seal will just let oil leak on the back of the flywheel and get thrown outwards. Transmission input shaft seal is the one that will allow the clutch to become contaminated. I'd lean more towards a clutch that's just plain worn out though.
Old 01-25-2017, 11:00 AM
  #381
deschlong's Avatar
Small mod, but one I've had my eye on for a *really* long time. Finally sourced an original LHD power window out of Europe that has Auto-UP!!!!! It was a grey switch, but I swapped the internals over to my existing black switch and all was good in the world.
For those of you who don't know what this is, it's a LHD switch with both Auto-DOWN AND Auto-UP! This is significant because while all RHD switches had this feature, it existed only on certain "Scandinavian-market" Civics in LHD form. I once ordered a switch from Sweden in the hopes it would be correct but it turned out to be just a standard one without. While it's possible to mod an LHD one with RHD parts, I wasn't keen on doing this and it turns out now I don't have to. Here's a further write-up with more details on these switches: https://honda-tech.com/forums/honda-.../#post51070001
Note "X" on the back side: Indicates it has Auto-UP. (Image courtesy "Teal93Hatch")
Old 02-12-2017, 08:19 AM
  #382
kreggor's Avatar
Nice score, Deschlong. It's the little tweaks that make me smile, sometimes (like the intermittent wiper mod, or the lights-on chime mod you wrote up -- actually not so little if you prefer a working battery). Glad to see you're still making upgrades to this car. Any updates on your AWD Civic project?
Old 02-12-2017, 08:52 PM
  #383
deschlong's Avatar
Civic 4WD in its natural habitat.
Old 02-14-2017, 06:24 PM
  #384
Fish Twig
tony_2018's Avatar
Ah...So this is where you've been hiding. I'll back track to read up.
Old 03-22-2017, 02:49 AM
  #385
Offlimits's Avatar
Still alive?
Old 03-23-2017, 01:04 AM
  #386
1992BB2's Avatar
So many cool things in this thread.
Old 03-23-2017, 03:15 PM
  #387
deschlong's Avatar
Originally Posted by Offlimits
Still alive?
Yes!
Thx!
Old 03-23-2017, 05:52 PM
  #388
1992BB2's Avatar
Don't leave us Prelude fans out. If you ever see any cool Prelude stuff, I wouldn't mind seeing them. The EDM ones had some really cool options in them.
Old 05-23-2017, 09:32 AM
  #389
H-T Premium Sponsor
Hasport's Avatar
nice thread and hatch. enjoyed the read and all the little things you have done to the car to make it what it is
Old 05-23-2017, 12:56 PM
  #390
Premium Member
Oh man, if you tell me they have the H55F 5-speed gear box, I will lose my mind!
Somehow I lost track of this thread. I thought I had subscribed, but I never got any updates. I do not come to the cosmetic forums all that often.
Old 05-24-2017, 01:51 PM
  #391
deschlong's Avatar
They're all manuals, but I dunno about which specific gearbox they have.
Old 05-25-2017, 08:38 PM
  #392
leochilo's Avatar
Subscribed for more rare Honda goods
Old 05-28-2017, 04:01 AM
  #393
ceelx's Avatar
Was thinking you might need this set
Old 05-28-2017, 05:40 AM
  #394
Angelsbeamer's Avatar
This is an amazing build thread. So much oem goodness in here.
Old 06-20-2017, 07:32 AM
  #395
ragingcedar's Avatar
So with this auto up master switch, is there any other modding that needs to be done or is it just a plug in play type deal?
Old 06-22-2017, 09:42 PM
  #396
deschlong's Avatar
Plug 'n' Play, baby
Old 06-23-2017, 07:20 AM
  #397
Shoot! That confirms my suspicions then. I was able to locate a auto up switch but none of the auto features work Guess ill have to keep looking.
Old 06-24-2017, 06:33 PM
  #398
deschlong's Avatar
Could be something wrong with the switch. Does it do the extra click in both directions?
Old 06-25-2017, 07:31 AM
  #399
Siiick man, updates please! Subscribed
Old 06-25-2017, 11:29 AM
  #400
Yeah im pretty sure the switch is messed up somehow. It does have the extra click in both directions. Ive taken is apart as far as i can to check the solders to be sure none of them were broken, and as far as i can tell they look good. I'm guessing something else in the circuitry is bad.
Quick Reply: deschlong's restoration of a '93 Si Hatch - lots of OEM goodness
