toda C spec install
Old 04-22-2004, 12:41 PM
TsukubaSpec's Avatar
Default toda C spec install
I want to know the all the spec for installing my toda C!!!
Old 04-22-2004, 12:55 PM
Casey's Avatar
Default Re: toda C spec install (DC2_StAr)
toda/rocket motorsports springs. ti retainers wouldnt be a bad upgrade either. cam seals if theyre bad. adjustable cam gears to get the most out of your cams. new timing belt/power enterprise/toda timing belt for piece of mind. do valve lash to what toda recommends.
Old 04-22-2004, 01:35 PM
Default Re: toda C spec install (Casey)
yes I have all,I want to know the valve ajustement,valve lash...
Old 04-22-2004, 03:10 PM
regamaster's Avatar
All TODA Racing camshafts must be tuned using TODA adjustable campulleys to attain maximum performance. Valve lash for all cams is 0.2mm cold. Spec B & C camshafts require TODA valve springs. For Spec A camshafts, the following Honda/Acura valvetrain components maybe used up to 8400rpm on both the intake and exhaust side.
Per Toda's website !
Old 04-22-2004, 04:34 PM
Default Re: toda C spec install (regamaster)
its all I have to know!!??thanks
Old 04-22-2004, 08:42 PM
10000rpm's Avatar
lash is .008 intake and exhaust toda cam gears will match nice and perfect use assy lube
yaya
08-03-2003 02:46 PM
ak-s2000
07-20-2002 08:00 AM
Down_Und_R
05-28-2002 04:51 PM
00 Si
13
09-19-2001 07:16 AM
Quick Reply: toda C spec install
