pistons hitting (gsr problem 911)
GSR Block BORED TO 81.5mm, 95mm crank, custom piston rods, wiseco pistons 11.5 comp.... and ported gsr head. when we finally put everything on something hit when it was turned on. the platnium +4 spark plugs were dent, the valved and the head was good.
CYLINDER 1 AND 4 ARE LOOSE, THEY MOVE SIDE TO SIDE. AND THEY HAD OIL ON THEM??? WHAT DO YOU GUYZ THINK IT IS. DO YOU GUYZ THINK IS THE RING SEALS???? OH AND ALSO THE SPARK PLUGS WERE CHANGE TO DENSO SPARK PLUGS AND THEY DID NOT HIT....
my mechanic triple checked the clearance and said it doesnt hit with the denso spark plugs. he cranked it by had multiple times and besides piston 1 and 4 being wigglely everything is fine. DO YOU GUYS THINK IT CAN BE THE PISTONS RINGS??
Modified by LILSOWEK at 6:31 PM 9/18/2007
Modified by LILSOWEK at 8:37 PM 9/19/2007
Re: pistons hitting (LILSOWEK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote">i have FS: GSR Block 95mm crank, custom piston rods, wiseco pistons 11.5 comp.... and ported gsr head. when we finally put everything on something hit when it was turned on. im not sure how to find the clearance??? can anyone help??? or what do you guyz think the problem is..</TD></TR></TABLE>
so you didn't even clay the motor????
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote"> or what do you guyz think the problem is..</TD></TR></TABLE>
amateur engine builder with a non amateur task at hand i think i nailed it.
now you are selling it??<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LILSOWEK »</TD></TR><TR><TD CLASS="quote">i have FS: </TD></TR></TABLE>
Re: pistons hitting (lohatch)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lohatch »</TD></TR><TR><TD CLASS="quote">now you are selling it??</TD></TR></TABLE>
LMFAO x9234823948239482394823
Re: pistons hitting (Hamstr323)
im just gettin into the honda all motor build how do u "clay a motor". I understand the concept but I would like to know what to use and how to exactly do it.
Re: pistons hitting (all-mtr-teg)
that might be the issue there. but id go LS rods 95 stroke, custom compression height piston. then again hes new to all motor hondas, he wouldnt know.
well my friend is the one building the engine for me, and i had bouught the bottom block with 95mm cranck and custom rods with wiseco pistons and they had told me that it was set up already, i dont know much about building an engine and i guese my friend doesnt know either now that this **** happen.....
Re: (LILSOWEK)
should have done some research, i am by no means an engine builder or a great mechanic, but with the help of many of these guys on HT i just completed my own build by myself and some machine work of course, but now my motor runs great and the month of research and work has payed off.
I feel like the search police but... use the search. Claying the motor has been described a number of times. And there are 100s of posts with different builds and what works and doesn't work... so just spend a few hours searching the forum and then you will be all set.
/Carl
/Carl
all right thanks for the help guys. now i have to go tomorrow to my friends house to see the engine taken apart to see what got mest up. hopefully not a lot..... im going to pray a lot tonight!!!!
Re: (LILSOWEK)
if he used KR6 plugs they usually get dented in high comp all motor applications, even thou u most likely got 2cc pistons, and more if its a weird combination and even more with most likely mismatched parts in the rotating assembly.
Re: (Chris Tune)
something about this worries me lol maybe its the fact that the owner doesnt really know anything about the motor hes trying to build. something tells me his pistons are up out of the hole because he used the wrong rods and or pistons for the crank. 1.check ur valves when u pull the motor apart. 2.check ALL of your clearences. 3. check ALL of your clearances AGAIN. someone definitly messed up somewhere.
i have FS: GSR Block BORED TO 81.5mm, 95mm crank, custom piston rods, wiseco pistons 11.5 comp.... and ported gsr head. when we finally put everything on something hit when it was turned on. the platnium +4 spark plugs were dent, the valved and the head was good.
